#11 |
What is the objective of the parralleled caps at the input, 8uF + .001uF + .68uF ? I understand the 8uF all by itself but the others? Was the orginal anticipating the 8uF would be some kind of electrolytic that didn't have flat bandwidth all the way out to 20kHz? Then there is the 150pF cap that filters HF. So first you let the HF pass then filter it off? If my WAG that it is a babdwidth issue reflecting limitations of ancient component why not just replace all three with one good quality 10uF metal film cap?
#12 |
As long as I'm asking questions: What is the intended benefit of a sliding bias? I tried stiking the diode and resistors in to an existing SPICE model to see what the effect was. Vusually, any before/after traces I plotted on any scale just sat on top of each other. The "after" subtracted .00006 from the THD figure. Not earth shattering if true and just as likely to be an artifact of the order in which the emgine does it's calculation. Or simple attrition of significant digits.
Assuming N.P. wouldn't put it in a design just for fun, is it a way of making optimum bias easier to set and to maintain under real conditions? |
#13 | |||
Thank you to everyone who has posted responses so far, they have been very helpful!
When I removed my ammeter from the negative rail and cleaned up the wiring a bit the oscillations stopped! Doh! Quote:
My older PS Audio amplifiers do not have it.Does anyone have any comments on the separate driver/output power supply topology? So far it looks like I'm getting 125 watts into 8 ohms, with a frequency response extending reasonably flat to at least 50kHz. Thanks again, everyone!!! |
#14 | |
It did not occur to me at first that it is a Sliding Bias. My initial impression was that it shuts down the drivers in the event the outputs went full positive or negative rails. You are correct about the 330p + 23k1. I have given the impression that it sets the dominent pole. It is indeed a phase lag compensation network set at 20KHz. Thank you for highlighting this. As for the 750pF at the drivers, the slew rate of the amplifier will be quite severely affected, leading to my conclusion of a bandwidth limited, high negative feedback design.
Michael Chua |
#15 | ||||||
There might be stability problems also if it oscillates after connecting the Zobel net. Hmm.... You might try an 8-10 ohm resistor in that net, but if moving the Zobel net off card does not help, I suspect you need to add a compensation capacitor on the VAS in addition to moving the Zobel net off card. The usual practice to ensure stability would be to place the main compensation cap from base to collector of the VAS, here the BD912 on the diode string. The typical value is 50-100pF. Quote:
But in the EF BJT case here it is risky. As has been pointed out elsewhere, if you aren't careful you will overdrive and saturate the outputs on clipping, and they will cross-conduct and self destruct. Baker clamps will prevent this. |
#16 |
Doug,
maybe you should move away those 750 pF and see if you still have oscillation. Those capacitors may give a too large phase lag before you have unity gain which is the same as oscillation. If you still experience oscillation: Afterwards you can, as pointed out by others, put a Miller cap between B & C ob the BD912 VAS stage, but start with a much smaller value than 750 pF! Tell us how it developed if/when you have tried it. SAM9, (Doug), I think you know that every capacitor have it's on fo, the smallest one on the input, 1 nF, do have propably a lower fo than 150 pF. But on the other hand, I think 1 nF in the input cap is overkill, by putting a good 100 nF the Fo is still very high, probably couple of MHz. This would be a better choice if RF is a concerne and the 150 pF will see a higher input impedance and make the work better if the smallest input cap is larger, eg. 100 nF. Regards
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears" Michael 29th January 2010 |
#17 |
Another question: Does the schematic imply lower voltage rails for the IS and VAS? It looks like it might but doesn't say so expressly.
#18 |
Oh yes, a 1uF cap across the 103R/2W resistor between the BD911 and BD912 in the output stage will probably reduce crossover distortion. The way I understand it is that when one driver turns "on" as the signal starts to swing in it's direction, it forces the other driver "off" by "stealing" current from it, thus making the transition between upper and lower halves of the output section cleaner.
#19 | |
Thanks, Doug |
#20 |
I think the MPS8099s will limit you to 38V in the IS, at least if you want to use devices that are safe even if expossed to the total rail-to-rail potential. MPSA42/92 would take care of that problem. In fact you could then simplify things by having a single set of rails.
| Amplifier Project | gbowne1 | Tubes / Valves | 16 | 24th April 2008 11:55 PM |
| Pre-amplifier Project Help | tumler | Solid State | 2 | 8th August 2007 11:15 PM |
| What is the best amplifier project...? | Danyele82 | Solid State | 11 | 2nd May 2004 03:05 PM |
| My new amplifier project | sajti | Solid State | 7 | 14th August 2003 03:15 PM |
| My amplifier project | JOE DIRT® | Solid State | 8 | 15th June 2003 03:37 AM |
| Page generated in 0.14984 seconds (84.12% PHP - 15.88% MySQL) with 11 queries |
