using 2 ohm loads on leach amp
The protection circuit will limit the current/power you can deliver to two ohm loads. Doubling the output stage and running rails on the low side ought to work to cure this, assuming that the driver stage can deliver enough current to run them. I've heard of people running 3 pairs of output devices. Not sure if there are any other issues with 2 ohm stability, though.
Looking at the circuit, I think it would happily drive 2 ohms and less with no problem provided that output devices [and its related base and emitter resistors] and heatsinks are doubled
No more modifications seem to be necesary since the drivers [MJE15030/1] have enough current capability and the current limiting circuit senses the current through a single output transistor instead of the full output current [ie: the limiting thershold is proportional to the number of output devices used]
[Halving and/or reducing even further the value of the resistor placed between the emitters of the drivers may help if oscillation problems arise. This will speed up output device turn-off at the expense of higher driver heatsinking requirements]
Power supply may also be taken into account but the difference will be only more or less sagging
"Is the leach amp capable of doing this?
For instance running four 8 ohm speakers on one channel?
If I have a 4 channel amp and I want to run 2 ohm loads (2 parllaled 4ohm speakers) what VA transformer will I require?"
I built a Leach output stage to run a 1 ohm load with ±80V rails.
It had ten pairs of MJ15024/25 outputs per channel, another pair as drivers, and a pair of 2N3585/2N6421 for predrivers.
The transformer should be rated at 2VA for every 1W out at the lowest expected impedance.
