DLH Amplifier: The trilogy with PLH and JLH amps
Old 27th August 2017, 02:00 PM   #11
diegomj1973 is offline diegomj1973  Argentina
diegomj1973's Avatar
One possibility to attempt to partially compensate for a variation of the output offset with the variation of the supply voltage could be as follows:
DLH Amplifier: The trilogy with PLH and JLH amps-posible-esquema-de-autopolarizaci-png
While that resistance could increase Johnson's noise in a sensitive part of the circuit, it would also increase the input impedance of the circuit by a ratio of 6 to 8 times the current values.
This resistance could be between 150 K and 180 K approx.
This has also not been tested, although in simulations reduces variations by a factor of around 2, relative to the first circuit.
Old 27th August 2017, 05:50 PM   #12
DLH Amplifier: The trilogy with PLH and JLH amps-dc-output-offset-vs-temperature-jpg
DLH Amplifier: The trilogy with PLH and JLH amps-dlh-amplifier-version-2-jpg
This version has not been tested, yet.
Old 27th August 2017, 06:34 PM   #13
DLH Amplifier: The trilogy with PLH and JLH amps-dc-output-offset-vs-temperature-version-3-jpg
DLH Amplifier: The trilogy with PLH and JLH amps-dlh-amplifier-version-3-jpg
File Type: jpg DC Output Offset vs Temperature (version 3).jpg (503.4 KB, 1389 views)
Old 27th August 2017, 07:58 PM   #14
Ketje is offline Ketje  Belgium
Ketje's Avatar
Last schematic makes no sense.Redraw it for a more usual look.
Mona
Old 27th August 2017, 09:17 PM   #15
Mona
Excuse me, but your subcircuit is not like the one I posted . Check it out, since it's not like mine . In your schematic you are connecting - V with ground, among other things ---> Booooommmmm !!! .
Anyway, this subcircuit could be arranged visually so that everyone can understand it better .
Old 27th August 2017, 10:18 PM   #16
Bigun is offline Bigun  Canada
Bigun's Avatar
Hugh Dean has posted something like this a few years ago and so did Broskie. Strange thng is I never saw anybody build it yet. Diego, now pressure is on you to build
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th August 2017, 11:48 PM   #17
The circuit is working perfectly. You can see my videos from the first tests. Tested with very bad speakers sounds beautiful.
I do not know what these people have done in relation to configurations that might be similar to mine. I only know that it far exceeds my expectations, although the schematic is not very flexible when designing it, compared to others.
I'm surprised no one has ever used a scheme like this, yet. My design employs a "rustic vertical differential amplifier". If the output is set in perfect push pull configuration, using two similar paired N channel mosfets, H2 cancellation is excellent and the distortion residue is extremely low. It is of total simplicity but its parameters of quality are enormously surprising.
I built the JLH version Update and, I can assure that compared under the same speakers, my circuit performs several times better than the JLH.
It does not mean that the JLH dislike me. Simply, my circuit reproduces much more realistic, without annoying wheezes, with greater bandwidth than the JLH.
I had no chance to build the PLH, yet.
Old 28th August 2017, 12:28 AM   #18
Bigun: Could you quote links from Hugh Dean and Broskie posts?
Old 28th August 2017, 08:10 AM   #19
AKSA is offline AKSA  Australia
The circuit was first described by Christopher Rush in 1964.
It is a series LTP, one single current, very fast and high gain.
It has two outputs, in antiphase, functionally like a tube concertina phase splitter.
Ideal for a quasi amplifier driver and transconductance set with a single inter-emitter resistor.
Essentially it is an emitter follower driving a common base.
The circuit was first used commercially by Tomlinson Holman in the 1973 NAD 3020 phono preamplifier which established a very high reputation for decades.
Nice circuit, Horacio!! However, nothing is new under the sun but you should be proud that this does not detract from your clever implementation of a quasi drive for a power amplifier. Who knows, you could be the next Spanish Pass!
HD
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 28th August 2017, 09:51 AM   #20
R.I.P.
Originally Posted by diegomj1973 View Post
an unusual way to present the squarewave tests.
Does the stopping and starting @ the zero volts reveal any extra information useful to a designer?
regards Andrew T.
DLH Amplifier: The trilogy with PLH and JLH ampsHide this!Advertise here!
Powering op amps from amplifier PSU Mrcloc Solid State 19 24th June 2016 12:39 PM
Circuit diagram for Trilogy VTi. harwoodspark Tubes / Valves 0 1st August 2007 06:36 PM
OP-AMPS in Marantz PM7000 Amplifier Alex2 Digital Source 2 18th February 2004 10:14 AM
OP-AMPS in Marantz PM7000 Amplifier Alex2 Chip Amps 0 17th February 2004 08:17 AM
OP-AMPS in Marantz PM7000 Amplifier Alex2 Analogue Source 0 17th February 2004 08:08 AM
