Idiot seeks help with Hiraga
Old 21st December 2017, 11:54 AM   #141
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Default Tent shunt
Hello,
Tomorrow Tent shunt supplies will be installed by a technician who already made some other changes in the original design used in the 20 watt Hiraga amp belonging to my friend.
We will see.
Greetings, Eduard
Old 21st December 2017, 01:48 PM   #142
m0rten is offline m0rten  Norway
Send a message via MSN to m0rten
I look forward to seeing your Hiraga project be a success!
Merry xmas!
Morten
;-) morten
Old 21st December 2017, 06:14 PM   #143
Hello,
The input stage of my friends Hiraga was changed in a way that I will kind of behave like a single ended amp. The output power is reduced 50 % by this modification.
My friend will surely keep me informed about the improvements the tent shunt did bring.
Greetings, Eduard
Old 21st December 2017, 06:29 PM   #144
cumbb is offline cumbb
cumbb's Avatar
A better solution for the psu.
Do NOT use the bridging MKPs. Remove! Or replace by 5 - 6 100F OR 220F OR 470F.
The ground RCA - board, I remember, is to alter.
And something others.
Your Cary Valves do sound MUCH better - do have the MUCH higher potential;-) Trust me;-) Change your speakers! And sources. The Hiraga A is a four-stage-complementary-parts-pp! Impossible to get a clean clear sound. NO CHANCE! That is a rumbling, roaring, noise-amp! Have built and tuned some;-P
And remove the copper-RAILS;-! Replace by 0,8 mm or 1,5 mm solid core.
Replace the litz-wire. Use solid core or coated litz-wire. MAX. 0,8 mm.
different/relative,-)
Idiot seeks help with HiragaHide this!Advertise here!
new member seeks info. giblaut762005 Introductions 1 4th November 2013 02:20 PM
new member seeks info. giblaut762005 Parts 0 3rd November 2013 08:22 PM
new member seeks info. giblaut762005 Parts 0 3rd November 2013 08:07 PM
new member seeks info. giblaut762005 Parts 0 3rd November 2013 07:59 PM
Newbie seeks driver approval markg Multi-Way 10 19th October 2002 05:39 AM
