Old 28th March 2004, 03:55 PM   #1
roger-k is offline roger-k  Norway
Default 128 step volume controled by relays
Have a look at:
An alternative attenuator/pot?
Roger
Old 30th March 2004, 12:15 PM   #2
MarekM is offline MarekM  Poland
Hi Roger,
What is the adventage of using so many relays for this task?
using 8 relays you are able to build 256 step attenuator.
Marek
Old 30th March 2004, 03:39 PM   #3
Hi Marek
What do you actually mean by that?
I am using 7 relays and have 128 step.
But offcourse I could add one more relay and get 256 step.
Roger
Old 30th March 2004, 06:33 PM   #4
Roger,
Sorry I was not precise. You use 7 double-contact relays, and 14 resistors, which have to be high accuracy ones. The idea I had in my maint was to use one serial resisstor and 8 resistors switchable to ground with following values:
N*2^0, N*2^1, N*2^2... N*2^7. This allows to reduce twice the number of relay contacts and resistors. Nothing special, but it simplifies the circuit :)
Old 31st March 2004, 08:42 PM   #5
Thats right, but I want to use 14 resistors, becorse if I use 8 resistors the circuit is not so flexible.
With 14 resistors the circuit have only two connections.
With 16 resistors the circuit have three connections and it is very easy to replace a conventional pot with the circuit.
I will use relays with two normally closed contacts and two normally open contacts and control both left and right channel with seven relays.
Roger
Reed relays in passive volume control? hermanv Analog Line Level 24 4th May 2008 03:50 PM
adjusting step of remote contoled volume? sapek Parts 18 2nd January 2008 12:24 AM
Relays for Aleph P1.7 volume control xenofex Pass Labs 0 28th April 2006 03:32 PM
Computer controled volume control madmax14304 Chip Amps 5 21st December 2004 11:23 AM
Whice place in hong kong can get thsi (step volume). bandan Parts 1 14th October 2004 02:34 AM
Page generated in 0.06967 seconds (74.86% PHP - 25.14% MySQL) with 10 queries
