Hafler DH-200/220 Mods
Old 16th August 2011, 05:03 AM   #971
rfj5106 is offline rfj5106  United States
How do you determine the optimum value for the choke?
Richard Jenkins
Old 16th August 2011, 05:59 AM   #972
djk is offline djk
R.I.P
djk's Avatar
The choke is for high-frequency noise, not hum.
Candidates for the Darwin Award should not read this author.
Old 16th August 2011, 05:45 PM   #973
rhr9 is offline rhr9  France
rhr9's Avatar
Hi ,
Here is a topic , ( on the french Elektor forum ) , about PI filtering :
alim et filtre en PI - ELEKTOR.fr | Électronique : Analogique Numérique Embarqué Microcontrôleurs Audio Test Mesure
@ + Philippe.
Old 25th September 2011, 12:56 AM   #974
eyoung is offline eyoung  United States
eyoung's Avatar
I did a bad thing... I bought a dh220 on fleabay. I have not got it yet to see what kind of basket case it is , I have not bought anything on ebay electronics that was working when I got It ....That said I have been lucky that I have been able to fix everything reasonably cheap. Stay tuned It looks like a pawn shop special (was working the last time I plugged it in)...
I am an amplifier addict. the fact that i happen to be drinking when I buy these wonderful amps means nothing....
Does anyone know how deep in class A you can bias or is there a sweet spot(to paraphrase another)
Burning in South Carolina... EL
"Lead me not into temptation...I can find it myself."
Old 25th September 2011, 01:14 AM   #975
ouimetnick is offline ouimetnick  United States
Send a message via AIM to ouimetnick Hafler DH-200/220 Mods
Normal BIAS for the DH-200 is 250mA. For the DH-220, it is 275mA.
You can go higher, but at the expense of more heat, and a slightly shortened life span. I'm not sure what the maximum you can go before something smokes, but I wouldn't go higher that 300mA.
Old 25th September 2011, 03:48 AM   #976
fab is offline fab  Canada
fab's Avatar
Hi eyoung
For more clarification, the output Lateral Fets are self protected against over temperature. The temperature coefficient (about 110-130 ma range per mosfet) change after some bias current value, so the more the temprature rises the more the current drops. Therefore, even if you try to increase the bias current, after some times, it will automatically reduces due to high temperature. The amount of reduction is also function of the size of the heatsink. I remember noticing that effect around 300ma ( bias for 2 pairs) or more - I think. I have already described it earlier in the thread.
The "sweet spot" for these Lateral mosfets is high bias current thus would require a bigger heatsink...or to reduce the voltage (I remember Nelson Pass indicating that this design can make a nice sounding class A amp)
Also, these amps have thermal cutoff switches when heatink temperature exceeds 70C thus you can try different bias current values without too much risk.
Good luck
Fab
Old 25th September 2011, 05:48 PM   #977
gp4Jesus is offline gp4Jesus  United States
...Does anyone know how deep in class A you can bias or is there a sweet spot(to paraphrase another)
I asked the same "class 'A' question elsewhere on this thread. They advised me (on an XL280) "pull back on the finals PS voltage to about 30; adjust bias until you can't touch the sinks." Also asked the question: "Would it be worth it?"
cheers tony
Samsung 60" LED, Outlaw 975 prepro, Samsung BDP, Charter DVR; Tri-amped(!) LR: Parasound 855 & 2 Rotel 980s ->Polk RTi A7 ; Tri-amped(!) CC: Rotel 985 ->Polk CSi A6; Mackie 1400->DVC 15 Sub; Surrounds: Hafler XL280->Polk RTi A3
Old 22nd October 2011, 07:44 AM   #978
woody is offline woody
Here is another idea. Convert the power supply from a full wave BRIDGE to a simple full wave supply. This way instead of having + and - 60v you would only have about 60v. Then use the type circuite used in one of the Quad amps to make a + and - supply from one voltage. Use the first circuite to get the 60V dc then the last 1/2 of the next circuite to get the split supply voltages. Then we should be able to run the bias a whole lot higher.
Old 22nd October 2011, 02:05 PM   #979
fab's Avatar
Default Class A higher current
You mean a virtual ground for a power amp and using half de power capacity of the actual tranformer.... why not change the transformer to a smaller voltage with same power rating then...
Old 22nd October 2011, 02:22 PM   #980
Rush is offline Rush  United States
Default Class A
Yes FAB, that's what I did. Worked out very well. I use it as a tweeter amp, running 17.5 VDC on each rail.
Hafler DH-200/220 ModsHide this!Advertise here!
Hafler dh110 mods anyone? amp_guy Solid State 5 30th January 2011 12:57 AM
Hafler xl-280 mods Audionirvana Solid State 5 11th November 2010 04:25 AM
Hafler DH 101 preamp mods Zen Mod Solid State 6 3rd May 2004 12:24 AM
