Hafler DH-200/220 Mods - Page 93 - diyAudio
Old 10th October 2010, 08:13 PM   #921
Default DH-200 versus XL280 PS caps.
Help?!!
I've heard from another hafler fan the "280" caps are superior to any other DH series PS caps
DH-200 model# & other info: 3186EE103U075BMA2; 362 8902 56699; 7800 micro F
XL-280 model# & other info: 3186DE782U075BJA2; 362 8710 56699; 10K micro F
both have the same voltage & temp specs.
also how do I measure '280 channel bias? I see the adjustment pot and I'm acutely aware of the importance of same, about 330ma I think.
thnx in advance, tony
Old 10th October 2010, 11:59 PM   #922
djk is offline djk
djk's Avatar
Pull one fuse on one channel circuit card, clip on ammeter, adjust, replace fuse. Repeat for other channel.
Candidates for the Darwin Award should not read this author.
Old 13th October 2010, 11:43 PM   #923
At the risk of igniting a heated debate, except for output, is Cat 5e a good replacement for any wire in an amp that carries signal?
If not, what would you hafler gurus recommend?
Old 14th October 2010, 12:23 AM   #924
whaleman's Avatar
I use CAT6 in all my amp signal level and have good results with 5E also.
WHALEMAN
The Cathedral Speaker Co.
Old 15th October 2010, 02:37 AM   #925
Originally Posted by gp4Jesus View Post
...except for output...
Here I meant "connecting the finals to the output jacks" Here I would use OFC 12ga
As for the Cat 5e, I have miles of it.
thanks tony
Samsung 60" LED, Outlaw 975 prepro, Samsung BDP, Charter DVR; Tri-amped(!) LR: Parasound 855 & 2 Rotel 980s ->Polk RTi A7 ; Tri-amped(!) CC: Rotel 985 ->Polk CSi A6; Mackie 1400->DVC 15 Sub; Surrounds: Hafler XL280->Polk RTi A3
Old 30th October 2010, 04:33 AM   #926
Default PS caps for a hafler XL-280
I have an extra set from an XL-280. Are these a good choice to improve PS capacitance & ESR?
I'd like to squeeze these into one of my '280s. is the effort worth it? The $ was right @ under $15 for 4 from ebay.
also how to check DC offset?
thanks tony
Old 4th November 2010, 10:20 PM   #927
Default XL-280 stuff
Two items:
1. Looking for power supply improvements or upgrade ideas other than those on TnT-audio.com
2. On the XL-280 schematic I noticed 2 types of grounds.
(Pg 17 of the .pdf)
One looks like a bent pitch fork (chassis ground?) The other, an inverted pyramid.
What concerns me is the 100nF caps that appear to rely on a chassis ground* connected to the final's PS rails near the MOSFETs.
* grounded through the heat sinks attached to case w/sheet metal screws.
Is it worth it to improve it? Can I run a connection to where C20 & C21 are grounded? Or where the RCAs have a way-better chassis ground?
Thanks tony
Old 5th November 2010, 09:02 PM   #928
Default DH 500 PS cap upgrade question
Nippon Chemi-Con or Mallory of about the same uF value?
Old 7th November 2010, 02:07 PM   #929
Originally Posted by scott wurcer View Post
... I run mine (bias) at 450mA (~50W)...
What do you mean "~50W"? Lower power by way of lower rail voltage?
You're welcome to PM your reply
Thnx tony
Old 7th November 2010, 11:36 PM   #930
djk is offline djk
djk's Avatar
450mA bias times 60V rail voltage is 54W bias (per channel).
This gives about 400mA bias in the outputs, so a peak bias of 800mA before going into class B, or 560mA RMS, which would be 2.5W/8R in class A.
Hafler dh110 mods anyone? amp_guy Solid State 5 30th January 2011 12:57 AM
Hafler xl-280 mods Audionirvana Solid State 5 11th November 2010 04:25 AM
Hafler DH 101 preamp mods Zen Mod Solid State 6 3rd May 2004 12:24 AM
Copyright 1999-2017 diyAudio
