Old 23rd July 2010, 01:47 AM   #901
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Originally Posted by Jacques Merde View Post
It might be easier to get an isolation transformer which will step the mains voltage down to 110.
Or even, as isolation isn't required, a variac. Out shopping recently I was surprised how cheap a 1kVA variac was. Cased up, it listed a bit lower than what I paid for a custom 1kVA toroidal.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Old 23rd July 2010, 01:53 AM   #902
abraxalito's Avatar
Originally Posted by scott wurcer View Post
I thought there is a dual winding transformer that simply requires the change of a couple of jumpers.
The man. shows two possible transformer types - the 'domestic' (T401) and 'international' (T402). If the OP has the domestic US variant, it has a single primary.
Old 23rd July 2010, 01:54 AM   #903
alexg is offline alexg  Philippines
alexg's Avatar
Other than the mains voltage, is there another reason you want to replace the EI transformer with a toroidal? It might be easier to get an isolation transformer which will step the mains voltage down to 110.
Actually, the price of the toroidal and the price of a decent step down (1KVA) is almost the same locally.
So, am more inclined to replace the transformer to avoid clutter.
Another option that I am thinking is having the EI transformer, re-wound for 220VAC primary. Labor in our country is so inexpensive.
Am trying to avoid having a 110V audio equipment, am a klutz and I might plug it on my mains outlet and burn the Hafler.
Old 23rd July 2010, 01:57 AM   #904
abraxalito's Avatar
Copper's not though so hopefully you'll get scrap value back on the 120V windings (which will be thicker wire as fewer turns).
Old 23rd July 2010, 02:26 AM   #905
alexg's Avatar
Actually, copper is not that expensive, the core is more expensive.
I just talked to a friend who owns a transformer factory, he will wind for me and just give me the bobbin with the windings, I will try to recover the core from the original transformer and stack it myself to the new bobbin...
Old 23rd July 2010, 02:58 AM   #906
abraxalito's Avatar
It certainly seems relatively expensive here, when I bought a 100m reel of wire it was more than lunches for a week.
Sounds like a fun exercise. I still remember the old days when RS sold transformer kits for building your own EI. Only had to wind the secondary though - doing your own primary is more challenging I think. Stacking the laminations and not getting any rattles or hum may be an even bigger one...
Old 25th July 2010, 01:26 AM   #907
alexg's Avatar
I just replaced the 4 100uf electrolytics on the driver board with 4 220uf Panasonics (I have on hand used for bypassing tube projects, the Hafler is my first SS project). Sound is pretty much imporoved.
The board have a 470uf bi-polar cap, I cannot find better replacements, how low of a capacitance can I go? I have a bunch of polypropylene and polyester caps, the highest is 20uf... I wonder if I can use these instead.
Thanks.
Old 25th July 2010, 09:22 AM   #908
abraxalito's Avatar
You certainly can, but bass performance will suffer. This cap determines the low frequency roll-off of the amp. Reducing it by a factor of 20 sounds rather drastic... But try it and see what it sounds like. You could try substituting back-to-back 1000uF polarised electrolytics if you don't like the sound of your 20uF.
Old 26th July 2010, 08:31 AM   #909
alexg's Avatar
Back to back, does it mean, - connected to the -?
I asked if I can lower it because in vacuum tube circuits, hardly I would go beyond 2.2uf for an output cap.
Thanks.
Old 26th July 2010, 08:57 AM   #910
djk is offline djk
djk's Avatar
"hardly I would go beyond 2.2uf for an output cap."
Calculate the RC corner.
The R is 150 ohms. 20µF would then be 53hz.
Candidates for the Darwin Award should not read this author.
Hafler dh110 mods anyone? amp-guy Solid State 5 30th January 2011 12:57 AM
Hafler xl-280 mods Audionirvana Solid State 5 11th November 2010 04:25 AM
Hafler DH 101 preamp mods Zen Mod Solid State 6 3rd May 2004 12:24 AM
Copyright ©1999-2013 diyAudio
