Hafler DH-200/220 Mods
Old 5th December 2012, 11:23 PM   #1071
rsavas is offline rsavas  Canada
C1, according to National ap1849, to protect against turn-on/off spikes, Pioneer did not use it = optional
C3, Nationals idea, another optional, yes a film cap would do as well= better. I used 5mm lead spacing.
Thinking of adding 2 triacs, controlled by opto's, in series with the line & in parallel with K1 so that I can add MCU control option, would require separate power for MCU, more PS what can I say.
Old 30th December 2012, 10:21 PM   #1072
zcables is offline zcables  United States
I'm replacing the C5 470uF caps with new electrolytics, but I just realized that the originals are bipolar and my new ones are standard polarized. Which way should I install the polarized caps in the circuit, or will it not work at all?
Thanks for the help!
Old 30th December 2012, 11:17 PM   #1073
Got it; thanks!
Old 31st December 2012, 03:21 PM   #1074
amp_guy is offline amp_guy  United States
outboard softstart, hmmm smell of a good idea! as space in the Hafler chassis is non existant. Thanks for that!.
Oh yeah 470uf bi-polar = 2 1000uf polarized types connected in series, sorry.
Old 1st January 2013, 07:40 AM   #1075
djk is offline djk
djk's Avatar
Real easy to install a 2.5Ω thermistor on the terminal strip behind the power switch, I've done it several times.
http://www.digikey.com/product-detai...081-ND/2539563
http://www.digikey.com/product-detai...1158-ND/227599
http://www.digikey.com/product-detai...1170-ND/227611
http://www.digikey.com/product-detai...1146-ND/227587
Candidates for the Darwin Award should not read this author.
Old 9th January 2013, 03:46 AM   #1076
eyoung is offline eyoung  United States
eyoung's Avatar
Hola Y'all...
has anybody tried replacing lateral mosfets with hexfets ala IRFP240/9240???
Regards, El
"Lead me not into temptation...I can find it myself."
Old 9th January 2013, 09:48 AM   #1077
djk is offline djk
djk's Avatar
While in theory it could be done, I would not recommend trying it at all.
The bias circuit would have to be redesigned for the much higher gate voltages, and temperature compensation. The pin-outs are different. Source resistors would need to be added. The device threshold voltages would need to be matched. The frequency compensation would need to be changed. Fold-back current limiting would be a good idea, the IRF type do not protect themselves like the Hitachi type do. Etc.
But yes, it is possible.
Old 9th January 2013, 12:12 PM   #1078
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Hitachi=Renesas
Old 9th January 2013, 01:43 PM   #1079
djk is offline djk
djk's Avatar
Hitachi=Renesas=Semelab=Magnatec=ALFET=Exicon
(there may be others I don't know about)
Old 29th January 2013, 10:45 PM   #1080
stenks is offline stenks  Serbia
stenks's Avatar
Can someone tell me what the value of the resistor connected in parallel to the capacitors of 10000uF with polypropylene capacitor. I tried that I read here in the forum but to no avail.
Hafler DH-200/220 ModsHide this!Advertise here!
Hafler dh110 mods anyone? amp_guy Solid State 5 30th January 2011 01:57 AM
Hafler xl-280 mods Audionirvana Solid State 5 11th November 2010 05:25 AM
Hafler DH 101 preamp mods Zen Mod Solid State 6 3rd May 2004 01:24 AM
Copyright ©1999-2017 diyAudio
