Old 28th March 2004, 03:45 PM   #1
Default Clipping and load at same db level?
From what I understand, a lower impedance load on an amp will draw more power and sound louder, while a higher impedance load will draw less power and sound quieter. Is this correct?
My question is, in either case, if you turn the volume control so you get the same decibel level, which load will cause the amp to clip sooner, or are they both the same?
Old 28th March 2004, 04:50 PM   #2
Its simply depends on the amplifiers ability to drive low
loads, if it can they are better, it can't they are not.
sreten.
Old 28th March 2004, 05:15 PM   #3
sam9 is offline sam9  United States
sam9's Avatar
Most (all?) amp topologies I'm familiar with when put into a SPICE simulation clip further from the rails with lower loads. That is they will clip sooner. I can't say which will be loader because that's a function of the speaker's sensativity. The interesting thing about the SPICE simulation is that voltage source assume unlimited current and stlll lower loads clip sooner.
Convert Line Level to Electric Guitar Level miallen Solid State 4 16th May 2010 01:22 PM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 04:13 PM
Page generated in 0.06792 seconds (74.86% PHP - 25.14% MySQL) with 10 queries
