my CD880 headphone amp has 2 opamps parallel ( 1 NE5532 package ) for each channel. This sounds not as good as if one opamp from each package is disconnected. Bernhard |
#2 |
The one and only
I have played with massively paralleled circuits, including
ordinary op amps, and there are definite improvements to be had. At Threshold we nearly launched a preamp with 25 parallel stages for each section. Until we costed the parts out. |
#3 |
Maybe I misunderstood Bernhard, but I think he meant that he
found the sound better if using only one opamp instead of two in parallel as in the original design. There are right ways to parallel op amps and there are wrong ways to do it. Perhaps posting a schematic will help people to give useful comments on this observation. |
#4 | |
diyAudio Retiree
Nelson....... April fools day is not for 13 days. If that was a practice run the official entry is going to be a real whopper! |
#5 |
Fred,
Please don't get us started on Whoppers again. Last time it happened it seemed everybody preferred to talk burgers instead of discussing the original thread topic. |
#6 |
One sounds better than two.
Here is the schematic, followed all the tracks on the double layer pcb |
#7 | |
Account Disabled
the 150ohm resistors are summing resistors. They are there to even out any minor differences between the two amps / gain resistor networks so you don't end up in a situation where one opamp is driving the other like crazy. You can eliminate the muting circuit if you don't need it. the 47ohm resistors are for decoupling. yes, you can take them out. |
#8 | |
A commercial product should be able to drive a wide variety of loads - if it sounds better to you single that's how you should set it. Of course it will sound better without the mute. Why don't you build a new amp with less comromises using better chips? |
#9 | |
#10 | |
Go there because of one illness, and they will find another ten. Better rebuild the whole mainbord. |
| FS: Tubes, opamps and a sound card | sachi | Swap Meet | 10 | 10th September 2009 11:22 PM |
| Help with OpAmps frames & Sound Changes | irgendjemand | Solid State | 28 | 15th April 2008 01:43 PM |
| OpAmps wired in parallel | Alfetta87 | Digital Source | 7 | 20th August 2006 07:57 PM |
| Opamps changed => metallic sound | roibm | Solid State | 2 | 22nd March 2004 11:17 AM |
| The sound of concatenated opamps. | Circlotron | Solid State | 36 | 26th February 2004 03:15 PM |
| Page generated in 0.12914 seconds (72.10% PHP - 27.90% MySQL) with 11 queries |
