Krell KSA 50 pcb - Page 786 - diyAudio
Old 28th January 2009, 07:12 PM   #7851
Hello
I find this power suplly for ksa50 cann someone told me what values for L1 and L2
Old 28th January 2009, 08:49 PM   #7852
That is not a KSA50 PSU and it is not suitable for any KSA.
The +-10mF after the inductors prevents it working effectively.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th March 2009, 11:53 PM   #7853
Send a message via MSN to robson fulco
Hello good evening to all the friends ...
I'm wanting to mount the amp. Krell KSA 50 ..
I would like to know the size of two plates of the same ...
grateful for the help of friends ..
Old 12th March 2009, 09:29 AM   #7854
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Robby,
é voce fala sobre os disipadores de calor ?
37.5V * 1.8A *2 = 135W de calor o lado, no total 270W para estereo.
Without a fan (ventilador ?) you need a heatsink of 0.20 C/W minimum, or two heatsinks of 0.40 C/W for each channel.
(exemplo : Fischer SK56, 300mm*150mm*40mm, quatro partes para um ampli estereo)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 12th March 2009, 01:25 PM   #7855
troystg is offline troystg  United States
troystg's Avatar
Thank you Jacco, you are a true gentleman.
I had no idea what he was requesting because of my limited "English only" American ignorance.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 15th March 2009, 03:00 PM   #7856
Hello good afternoon to all friends!
I'm mounting the amplifier Krell 50 and I have a question ... which is connected to where this written LOW! and if so it needs only a tripot from 5k to perfect their operation ... I appreciate everyone's attention!
Old 15th March 2009, 03:10 PM   #7857
pictures from power!
Old 15th March 2009, 03:48 PM   #7858
the two connections @ LOW go to a single pole switch or to a SPNO relay.
It gives the option to reduce the Bias to suit warm weather conditions or as a low power standby rather than switch off.
The LOW could be optimum ClassAB and the Normal could be the full ClassA bias.
Another option could be to monitor heatsink temperature and use a relay to switch the amp to a lower ClassA bias to reduce the heatsink temperature, with a warning light to tell you something is wrong.
Be careful to set the two bias pots to work as one adjustment for LOW bias and the other to work in parallel to give the high (normal) adjustment. Check the schematic in case I've got this back to front. This is not on the later PCB, I wish it was.
regards Andrew T.
Old 16th March 2009, 12:53 PM   #7859
Hi!
I tried to pair transistors and the results are very divergent Hfe ~ 50%
My measurements:
MJL21194G 4 pcs. 884,890,867,925 mA
MJL21193G 4 pcs. 1370,1360,1360,1250 mA
How exactly pairs of output transistors to be paired?
Old 16th March 2009, 01:06 PM   #7860
what are you measuring?
I see mA, that is not hFE.
How are you measuring?
How are you maintaining comparable temperatures?
regards Andrew T.
Copyright ©1999-2017 diyAudio
