Krell KSA 50 pcb - Page 782 - diyAudio
Old 23rd December 2008, 07:26 PM   #7811
neychi is offline neychi  Croatia
@Nico, yes I measured voltage on emitter resistor, between transistor emitter and speaker output (+)
@Andrew, 0.3V cca
Old 23rd December 2008, 07:32 PM   #7812
Nico Ras's Avatar
@Andrew, 0.3V cca
You say that it plays music okay but you cannot adjust bias. What voltage are you measuring over the emitter resistor. I am thinking maybe that the Vbe multiplier is open circuit.
If this is the case then the amplifier will still operate but in class B or maybe a very small quiescent current, but you should still see a very small voltage change if you turn the pot.
Old 23rd December 2008, 07:35 PM   #7813
Nico Ras's Avatar
If you suspect the Vbe multiplier also then change it. Use any NPN transistor even a small signal type it will work. It does not have to be on the heat sink for testing purposes. If it works after the change then you know what the problem is.
Old 23rd December 2008, 07:43 PM   #7814
Ok, now I saw that on Wiki:
"Slowly turn the bias pot to increase the output idle current, you can also measure this as the voltage across the 25ohm driver emitter resistors, nothing happens at first, basically until the board output voltage reaches about 1.2v across r127 & 128, then the outputs start to turn on and you will read a voltage across Re1...keep increasing until you have about 0.2 volts across Re1..."
I'll try once again tomorrow.
Old 23rd December 2008, 07:51 PM   #7815
Thanks Nico
Maybe I didn't turn the bias pot enough. But I was thinking that after several turns some difference will appear.
Old 23rd December 2008, 08:11 PM   #7816
Nico Ras's Avatar
Thanks Nico
I am happy for you that it is changing. Most multi-turn pots have 25 turns so it needs several turns to make a change, this is good. In the low bias state you can run the KRELL CLONE in class AB, it is quite happy and will operate cool under almost all conditions. For it to run in class AB mode adjust low bias for about 25 mV across Re of output transistors.
Good listening.
Nico
Old 24th December 2008, 08:32 AM   #7817
Hi Guys!
Well, it's WORKING!!! I set the Bias at 1.9A, it is hot, but not too hot, cca 50 C after one hour.
Thanks everybody!
Old 24th December 2008, 08:41 AM   #7818
which part is ~50degC?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th December 2008, 08:56 AM   #7819
Heat sinks for output transistors and heat sinks for drivers are on the same temperature. Heatsinks for outputs first go hot around the transistors but after few minutes temperature is the same all around.
I can put my fingers on the transistors without problem.
Old 24th December 2008, 09:30 AM   #7820
Nico Ras's Avatar
WOW! That is a beautifully machined box, resembles the real KRELL stepped front panel and all.
Nico
Copyright 1999-2017 diyAudio
