Krell KSA 50 pcb
Krell KSA 50 pcb
Old 5th November 2007, 07:01 PM   #7471
Landoctor is offline Landoctor  United States
Hopefully this will help some of you out that were looking for transformers for this project.
You could also use the dual secondaries for +60 / -60 without the center taps. Then using the 100V primaries I measured 72.85VAC each. You could build a pretty beefy amp with that voltage for each rail. I come up with 103VDC for each rail in that configuration.
Let me know if any of you buy these. I would like to know what you think of them.
Thanks,
Donovan
Donovan
><(((º>.·´¯`·.¸¸.·´¯`·.¸><((((º>.·´¯`·.¸¸.·´¯`·.¸> <(((º>.·´¯`·.¸¸.·´¯`·.¸><((((º>
Old 5th November 2007, 07:07 PM   #7472
I'm not sure what they are made from, or if you can add them to an existing transformer.
I know they are pretty standard in higher end torroids used for audio. I have seen them on the Plitrons, etc.
I think it helps to contain the magnetic flux, so you get less interference from the transformer.
I'm sure someone around here could explain it to us.
Thanks,
Donovan
Donovan
Old 5th November 2007, 07:15 PM   #7473
I modified my 1000VA transformers from 74-0+74-0 to 37-0 times four.
Initially I ran the secondaries in parallel but the rectifer got too hot to touch (no sink fitted).
I changed to dual rectifiers, with a single rectifier across each 37-0-37, then paralleled the outputs of the rectifiers.
Sharing the secondary current this way made the rectifiers run much cooler.
regards Andrew T.
Old 5th November 2007, 08:20 PM   #7474
Default Transformer update
Here is the link to Scott's e-bay sale;
http://cgi.ebay.com/Toroid-TI-043222...QQcmdZViewItem
Apparently the transformers I got were a little different than the models he has listed on e-bay and he is out of the model I bought now. The model on e-bay is very similar, it just has a bit different secondary voltages (~29.4-0-29.4 unloaded). They are perfect for what we are doing with them in this project.
Thanks,
Donovan
Donovan
Old 6th November 2007, 12:15 AM   #7475
john65b is offline john65b  United States
john65b's Avatar
I bought one also - $40 best offer +$19 shipping... still waiting for it.
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 6th November 2007, 05:16 AM   #7476
imix500 is offline imix500  United States
imix500's Avatar
I bought one a few weeks ago. good quality and can't beat the price!
Old 7th November 2007, 08:14 PM   #7477
Motobias is offline Motobias  Germany
Send a message via ICQ to Motobias
Default Cerwin Vega a-2200 ?Mark. A. G.?
Hello everyone,
i stumbled across this wonderful forum when is was looking for information about a cerwin-vega a-2200 amp which i bought for a bargain on ebay germay
unfortunately i don't have any further information about this amp and i would be very thankful for any detail i can get !
Mark A. G. mentioned in some thread, that he got one of the same kind and is currently modifying it ?!
Thank you !
toby
Old 16th November 2007, 03:58 AM   #7478
bobgroger is offline bobgroger  United States
Just got 2 of these. Great quality. They have a bel canto part number TT250 Rev E on them. KSA50 is underway, enclosure is only part to be obtained. Have some HUGE heatsinks, bigger than any Krell I have ever seen. 39 pounds per channel. Thinking of 4 pairs a1943\c5200 and 2 pinkmouse driver boards to minimize lead length. Hope Mark has a few more boards....I need 4 more for driver and output boards.
Bob G.
Old 16th November 2007, 07:15 PM   #7479
bencat is offline bencat  United Kingdom
All of this seems to refer to a Krell KSA 50 Mk II . I am not sure what the exact differences are with these two. I own and use an original KSA 50 Mk I and this is the big heavy unit with full 50watt class A output and a fan that is noisy but very nessesary as the unit does run very hot when it is idling.
Mine has a small amount of work done ,change to schottky diodes , Kimber bypass caps, but is mostly as standard. Sound is very good indeed with great bass weight and very smooth powerful powerful sound without being too shrill and relentless as some solid state amps can be.
Is there a good schematic about for the KSA Mk i unit ?
Bencat
PS the big difference with KMA units is that they moved away form pure class A to what Krell describe as Plateaux Bias Class A. Probably a very clever circuit but not as purs as just the original Class A .
Old 16th November 2007, 08:06 PM   #7480
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
You are very welcome to post a piccy of the insides, especially a closeup of the front end snatch.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Krell KSA 50 pcbHide this!Advertise here!
