Krell KSA 50 pcb
Krell KSA 50 pcb
Old 16th March 2007, 04:11 PM   #7321
kmj is offline kmj  Sweden
kmj's Avatar
Oh, great. That took a load of me mind
Now I'll just switch the busted transistors on the other channel, move everything back into the case and turn up the bias to 400mV or as much as the heatsink can tolerate.
.....Where the music comes to die.
Old 16th March 2007, 04:15 PM   #7322
Hi Kmj,
0r68 and 400mV gives Ire=0.4/0.68=0.588A.
Ibias = 3*0.588=1.76A.
The peak (ClassA) current into a load, for a push/pull amplifier, is 2*1.76=3.53Apk
ClassA power = Ipk^2*Rload/2=3.53*3.53*8/2=50W ClassA
Peak voltage at max ClassA power is Ipk*Rload=3.53*8=28.24Vpk=20Vac.
This is worth saving and putting into a text file, or better, into a spread sheet.
Personally I would bias for 1.76+0.1 amps to ensure the very curved knee in the transistor Ic vs Vbe at the near change to ClassB is avoided. I think running into this low Ic region causes an increase in open loop distortion and makes the NFB work very hard. I think that's why ClassAB produces more distortion when biased above optimum.
I would also bias for the minimum impedance presented by the speaker rather than the nominal impedance. These extra levels of Iq will make the output stage run hotter and require larger heatsinks.
regards Andrew T.
Old 16th March 2007, 04:29 PM   #7323
kmj's Avatar
Hi Kmj,
I have the calculation bookmarked but since it was a while ago I though that I rather ask one extra time and have it confirmed than make a misstake and have the amp unfinished another couple of months
Isn't that the same as 400mV across the resistor? I only meant to lower it if the sinks couldn't handle the needed dissipation.
Old 16th March 2007, 04:42 PM   #7324
no.
Vre=400mV gives Iq=1.76A
Vre=423mV gives Iq=1.76+0.1A (1.86/1.76*400)
Adjusting the bias to achieve ClassA into a 6ohm load and reach the same peak voltage will require the bias to be increased to 2.45A and Vre=558mV
regards Andrew T.
Old 25th March 2007, 10:15 AM   #7325
kmj's Avatar
I thought of a thing, the transistors on the driverboard are the MJE15032/33. I can't find them over here but the MJE15030/31 are available. If I would need to change these on one of the channels, are the compatible or do I need to change them on both channels? I heard that these are virtualy the same models.
Old 25th March 2007, 10:17 AM   #7326
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Don't,
send me an email, i'll mail you the 32/33.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 25th March 2007, 10:23 AM   #7327
kmj's Avatar
email sent
Old 25th March 2007, 11:00 AM   #7328
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Krell KSA 50 pcb
The 30/31s do work in the circuit, so if you want to get going, install them for the time being until you get the others.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 25th March 2007, 11:03 AM   #7329
kmj's Avatar
Thanks, but Jacco's on it!
Old 29th March 2007, 11:07 AM   #7330
dr.strangelove3 is offline dr.strangelove3  Netherlands
dr.strangelove3's Avatar
I have skipped my KSA-50 project and moved on to the KSA-100 MKII. So now I have two very nice kits left. Troy did a hell of a job making all these kits! Al the electronic parts to stuff the Pinkmouse PCB's to make two channels. Except the output transistors. All quality parts like dale resistors.
I'm asking what I payed for them. 75USD excl. shipment. So if someone is interested, send me a PM.
Krell KSA 50 pcbHide this!Advertise here!
