Old 4th December 2005, 11:26 AM   #5001
Lgreen will be resigning I'd guess. He won't be able to live with himself.
regards Andrew T.
Old 4th December 2005, 11:33 AM   #5002
pinkmouse's Avatar
Pah, that'll teach me to take my eye off the ball for a moment!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 4th December 2005, 11:42 AM   #5003
K-amps is offline K-amps  United States
K-amps's Avatar
You know that 60 second posting limit seemed like an eternity to me! It was like chasing the last seconds of an auction, Zap, Zap Zap.
Old 4th December 2005, 11:56 AM   #5004
troystg is offline troystg  United States
troystg's Avatar
Al-
Looking for C109 on your boards.
Is it bottom mount?
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 4th December 2005, 11:58 AM   #5005
pinkmouse's Avatar
Hmm. Let me think about it. It may well be an ex-capacitor
Al
Old 4th December 2005, 12:05 PM   #5006
pinkmouse's Avatar
Ha. It's the cap across the bias trannie.
The "erratic" component designators on the silk layer was one of the things I noticed when I got the real boards. I would have liked to have changed it, but then If I changed everything I wanted to on these boards you would still all be waiting for the first run.
Al
Old 4th December 2005, 12:16 PM   #5007
troystg's Avatar
C104 and 109 are spec'd to be the same size.
C104 is just to the right of the input so that shows the size, but Since I am triple checking EVERY component, I need to find/ try 109 too.
Also, how critical is the 100n? I have not found a part # for that value in hole through.. Only in surface mount.
Troy
Old 4th December 2005, 12:23 PM   #5008
troystg's Avatar
Ah... Driver board... Why 109 and not 409?
Never mind, small potatoes...
Anyway, I am not having luck finding 100nF. What can it be upped to safely?
Or what did you use there(make / spec)?
Troy
Old 4th December 2005, 12:36 PM   #5009
pinkmouse's Avatar
I think I used Wima MKP10 to start with, but then just put in generic foil/film encapsulated type.
Al
Old 4th December 2005, 12:39 PM   #5010
VT67 is offline VT67  Belgium
VT67's Avatar
Troy
Epcos has a type with a 10mm pitch.
They are available at Digi-Key.
Page generated in 0.16100 seconds (69.22% PHP - 30.78% MySQL) with 11 queries
