Old 5th August 2005, 08:56 PM   #3601
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Can you think of a better birthday present, Mark ?
Looks like Sponge Bob has killed another thread.
Old 5th August 2005, 09:45 PM   #3602
jajabin is offline jajabin  United States
I am considering to join the kit group buy. However, my board is Jan's version, not pinkmouse's version. Are they using the same BOM?
Wing
Old 5th August 2005, 09:58 PM   #3603
googler is offline googler  United States
Wing
I believe that the BOM for the kit buy is from Jan's website www.delta-audio.com. It should be the same for both boards. PinkMouse had posted a BOM from his proto as well with some substitutions about 20 pages back.
~Brad
Old 5th August 2005, 10:47 PM   #3604
K-amps is offline K-amps  United States
K-amps's Avatar
Yes I beleieve Troy is using Jan's BOM.
Old 5th August 2005, 10:51 PM   #3605
I would only use Jan's BOM if you want to stay true to the original MK-2 design.
Mark
Old 5th August 2005, 10:56 PM   #3606
VT67 is offline VT67  Belgium
VT67's Avatar
jajabin
If you didn't found it already, here is Al's BOM.
Pinkmouse BOM
OK, in case some of you start missing me, I'm going to try to install my wireless network now.
Cheers
Old 5th August 2005, 11:25 PM   #3607
Just compared both BOM.
They are pretty much the same.
Thank you guys
Wing
Old 7th August 2005, 08:10 AM   #3608
pinkmouse's Avatar
Terry, glad you got sorted. It still seems really strange that the problem was with the PSU side, and yet only affected one channel. Still, I gave up trying to find logic in electronics failure a long time ago!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 7th August 2005, 09:16 AM   #3609
lgreen is offline lgreen  United States
lgreen's Avatar
Default Krell Clone Activated
We Have iginition.
Before I post a lot of pics ..... I just want to say thank you to Stewart and Jacco
for helping me with this tough project.
And also thanks to
everyone else including Terry for your comments, kind of forget who said what.
This project was not easy.
Right now, this is running about 20W class A in "low" bias mode
and slightly over 50W in "high" bias mode. Sound is great,
square wave response is awesome. Its 2:21 am and I've got
over 1200 songs left on the ipod! In "high" bias mode I get
about 63 degrees C on the output heat sinks, with the 2 fans
turned down so that they don't mae a lot of noise.
Man, setting bias is time consuming, I'm going to run down the
battery in my DMM. I've been running this since 12 and as things
heat up bias is unpredictable. I'm withing .01 V on bias between
channels but trying to do better
DC offset is .02 to .03 per channel, and I can't adjust this since in
my "chassis" a lot of stuff is not reachable.
Old 7th August 2005, 09:22 AM   #3610
pinkmouse's Avatar
Very nice! More pics please.
Al
Page generated in 0.15565 seconds (68.79% PHP - 31.21% MySQL) with 11 queries
