Krell KSA 50 pcb Krell KSA 50 pcb - Page 283 - diyAudio
Krell KSA 50 pcb
Krell KSA 50 pcb
Old 25th June 2005, 04:40 PM   #2821
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Krell KSA 50 pcb
Terry, Q108/9 run pretty cool. Q109/10/11 all need isolating from each other.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 25th June 2005, 05:23 PM   #2822
Coulomb is offline Coulomb  England
Coulomb's Avatar
Originally posted by Mark A. Gulbrandsen
There are also available stainless steel star type washers as well as regular type stainless lock washers.
Yes, they have to be insulated with what ever you prefer to use...... These devices have full rail potential on the collectors(metal tab). I use ceramic-alumnium oxide insulators on all my devices cause I can get em cheap at surplus.
Mark
Hummmm Mark do you use plastic srews?
Anthony
I like to stay current!
Old 25th June 2005, 05:53 PM   #2823
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
I have used them on a few occasions in a pinch! Later on to be replaced by the real thing.
Mark
Old 25th June 2005, 06:33 PM   #2824
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by still4given
Don't Q107 & 108 need heatsinking?
Terry,
if you look at the datasheet for the 15032/33 you can see 2 power figures: 50 watts and 2 watts, for Tc and Ta.
In the Safe Operating Area graph there are 2 lines as well, one for Tc, the other for Ta.
Ta is for ambient, without heatsink.
Tc for cooled, with infinite large heatsink.
Means the MJE's can dissipate 2 watts at 25C without cooling, even at 55C they do 1.5 watts without heatsink.
Even under the worst load dissipation of Q107 and Q108 is a fraction of what they can handle without heatsink.
Which is good, because they will only heat up a little, in return that will keep their parameters fairly constant.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 26th June 2005, 12:18 AM   #2825
neychi is offline neychi  Croatia
Well, that's it for today. I'm going to sleep now.
Cheers
Old 26th June 2005, 12:31 AM   #2826
VT67 is offline VT67  Belgium
VT67's Avatar
Hi neychi
Your boards start to look very nice. What type are those bulky resistors on the output boards?
Old 26th June 2005, 04:49 AM   #2827
lgreen is offline lgreen  United States
lgreen's Avatar
Default input clipping spec
How many volts on the input will it take to clip this clone?
Of course I'm wondering whether the iPod will drive it to full output.
oooohhh....my faceplate gets here tues, can't wait to see if it fits!
Old 26th June 2005, 05:32 AM   #2828
apassgear is offline apassgear  Mexico
apassgear's Avatar
Beautiful boards Neychi
Old 26th June 2005, 07:27 AM   #2829
Walter, thay are metal-oxyde, 1k, 5%, 4.5W from Buerklin. Two in parallel for 0.5ohms, 9W. I'm planing to do another pair with Stuart's resistors 0R68 and TO3 transistors.
Tony, thanks
Best regards
Dean
Old 26th June 2005, 07:37 AM   #2830
I'm steel sleeping. 1R, 4.5W, 5% of course.
Krell KSA 50 pcbHide this!Advertise here!
Copyright ©1999-2017 diyAudio
