Old 25th March 2004, 01:22 PM   #1
Stocker is offline Stocker  United States
Question 1500VA...what do do?
I have a 1500VA transformer laying about that can deliver 50, 55, or 62 VAC depending on how it's wired (no center tap). I am not a fan of big hardware for a single channel (Pass designs) because of the size. So classA in general is pretty much out... but what else would you do? build a 5.1 integrated amp for a whole system? a house-destroying sub-amp? a 3-way stereo+sub amp? Would you make it discrete or all chip amps, or a combination of them?
Looking for ideas. Think outside the box. Winner receives a
Jesus loves you.
Old 25th March 2004, 02:22 PM   #2
Triamped stereo set up.
AC coupled mid and treble, possibly class A or enriched AB.
Bridged bass amps to get rid of the coupling capacitors.
Use 50V (bridged) for bass, 62V tap for midrange, 55V tap for treble.
sreten.
Old 25th March 2004, 02:42 PM   #3
UrSv is offline UrSv  Sweden
UrSv's Avatar
Design a virtual ground circuit to keep the rectified voltage divided to two rails and the use it for whatever you fancy with 2*33-44 VDC?
Didn't QUAD do that in for instance the 405?
http://home.jps.net/~shiloh/
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 25th March 2004, 02:51 PM   #4
moamps is offline moamps  Croatia
[/B]
IMHO, no.
regards
Old 25th March 2004, 03:08 PM   #5
sreten.
Never thought of that! Out of curiosity, why not use the 62V bridged for bass? Seems to me you want as high a rail as you can get for mo' power...
Anyhow, great idea.
It occurs to me that this is the perfect start for a VERY small subwoofer using ESP's P48 sub processor and P68, high power variant, bridged.
Jesus loves you.
Old 25th March 2004, 03:15 PM   #6
UrSv's Avatar
Originally posted by moamps
IMHO, no.
regards
Seems not. Maybe somebody else then...
UrSv
Old 25th March 2004, 09:02 PM   #7
Just trying to balance powers a bit, 50v bridged = 100V.
Assuming 8 ohm :
50V only would give ~ 100w bass : 25W mid : 25W treble.
using taps = ~ 100w bass : 38W mid : 30W treble.
Of course its far more complicated than the above,
different driver sensitivities and impedances etc.
sreten.
Old 28th March 2004, 05:57 AM   #8
slowhands's Avatar
Use a FW voltage doubler for +-95v rails. hang 2-3 300 wpc amps on it.
Amveco 1500VA medical grade isolation transformers boywonder Swap Meet 3 6th June 2009 08:09 PM
Plitron 1500va ycl Swap Meet 1 25th November 2005 12:50 PM
Fs: Plitron transformers 1500va + 1000va ycl Swap Meet 7 26th September 2005 06:38 PM
0-42 0-42, 1500VA Toroidals richie00boy Group Buys 10 23rd November 2004 11:24 PM
How to power up 1500VA toroid? supernet Everything Else 1 6th May 2002 10:27 PM
Page generated in 0.09607 seconds (81.10% PHP - 18.90% MySQL) with 11 queries
