Parasound HCA 1000 upgrade Parasound HCA 1000 upgrade - diyAudio
Old 15th June 2017, 07:06 PM   #1
srinath is offline srinath  United States
Default Parasound HCA 1000 upgrade
I just got one of these. I was thinking of upping those power supply caps.
There is a HCA1000 on ebay now with some big silver body caps in it.
The seller doesn't know what they replaced etc.
Could someone be able to tell me what else can be modded with bigger caps in this amp ?
Thanks.
Srinath.
Old 15th June 2017, 09:54 PM   #2
phase is offline phase  United States
I looked at that, and the parts that have been replaced are the ones that are best just removed.
Very nice design, built to a price point.
Probably a lot you can do here and there as far as parts go to make better smoother sound from that, as well as just for maintenance.
Main filter capacitors, local decoupling capacitors, bypasses, servo film capacitors, servo op amp, feedback resistor, diodes can be replaced for benefit, amp is fairly easy to work on.
Old 16th June 2017, 02:18 AM   #3
Let me look at what the original parts that were replaced were.
Also I will see if I can replace the power supply caps to the 1000 a specs.
Thanks.
Srinath.
Old 16th June 2017, 09:25 PM   #4
mjstriker5 is offline mjstriker5  United States
I would be interested in a little more detail on your recommendations on making this amp better. I have a Parasound HCA 2205 that is going to need a recap soon. Since I am in there might as well have a little fun with it. Don't know how similar these amps are but I do know from looking at the schematic for my amp that is also fairly straight forward.
Old 16th June 2017, 09:39 PM   #5
john curl is online now john curl  United States
john curl's Avatar
Keep it simple! Just raise the bias to as much as the amp can handle.
"Condemnation without Examination is Prejudice"
Parasound HCA 1000 upgradeHide this!Advertise here!
Parasound HCA-1000 problem manfred77 Solid State 15 13th November 2015 08:27 PM
Parasound HCA 1000- Need Power Switch TJames Solid State 2 9th November 2013 04:54 PM
parasound hca 1000 blows fuses srinath Solid State 8 3rd September 2012 10:26 PM
Parasound HCA-1000 upgrade Skorpio Solid State 15 11th August 2010 06:47 PM
For Sale: Parasound HCA-1000 2 Channel Amplifiers mhealy4998 Swap Meet 2 9th November 2009 10:28 PM
Copyright ©1999-2017 diyAudio
