A little study about two old germanium projects - diyAudio
Old 14th June 2017, 04:28 PM   #1
DIYBras is offline DIYBras  Brazil
DIYBras's Avatar
Default A little study about two old germanium projects
Hello friends of DIYAudio,
In last times I am making a lot of measurements, and someimes I like to dissect some projects, like this I show here: one Germanium amplifier, and a Germanium preamplifier. Both more or less "classics". The amplifier in one using AD161/AD162 output transistors, and the preamp is like one published in Discrete design: 2-transistor RIAA preamp (the Linsdale MM, with some minor alterations).
In next posts I will show the results (and I need to draw the schematics ) normally I build things WITHOUT schematics
Making cabinets for OLD projects (better later than never...)
Old 14th June 2017, 04:36 PM   #2
DIYBras's Avatar
The MM Dinsdale is modified to flat response.
Folows the result for OLG in 2 different supplies, and OLG vs CLG.
Old 14th June 2017, 04:38 PM   #3
DIYBras's Avatar
Results for maximum-minimum gain structure from test circuit (min-max pot settings), and resulting output noise
Old 14th June 2017, 04:42 PM   #4
DIYBras's Avatar
FF result for 500mV output with 5k load, and HD sweep for almost same level and same load, 20 to 30000Hz, showing individual harmonics (but 6H+ is summed)
I don't have this pre anymore; this are old measurements from last year (I've made this pre for a guitar player).
The schematic is at home, but tomorrow I post it.
EDIT: I used japanese Ge transistors instead of OC originals.
Old 14th June 2017, 05:08 PM   #5
DIYBras's Avatar
Default Now time for power amplifier...
...for it I have draw the schema now!
Is a conventional amplifier for AD162/2 usage, but I used Ge even for input (a low noise 2SB486), and bias differ from originals. The missing values for input bias I don't remember now but is only to match the quiescent output voltage.
Some results for (please see the figure notes, at lower left): measured open loop vs actual use closed loop, FFT for open loop condition, HD sweep for open loop condition, FFT for low output bias (~<20mA) and high bias (approx. 200mA).
First time I have built this amplifier is in 1996, when I found some Telefunken AD161/162 from a old car radio, and tried a classic circuit model, with success (in mono). Since then, I have made some betterments (from simulations, 2008; from measurements, in 2009), stereo version (2012) and a cabinet for it. I have fused the original Telefunken's in 2011 . Is far from being my better or preferred amp, but is like a timeline for me, since I have it from my DIY beginings (1996)... In fact, is the second amplifier I've made in my first DIY year.
Old 14th June 2017, 05:22 PM   #6
DIYBras's Avatar
Result for 1W/8R/20Vcc/250mAiq for this amp.
Is a fair result for a such simple amplifier, with early transistors, all alloy type (low Ft).
I like the ground connection for the "second stage" ("VAS"), is less prone to suplly ripple, but... maybe the bootstrap have less PSRR than the stage gain, if stage is the "classic" Vcc based? In 2009 I simulated this and preferred the VAS in ground instead Vcc.
Old 14th June 2017, 10:50 PM   #7
Zero D is offline Zero D  United Kingdom
I have a portable radio that uses GE transistors that belonged to my dad from the 1960's. I remember listening to it, & it still works & sounds nice as it did. Not HiFi, but a nice sound & has bass too None of that awful tinny sound many had !
All the best with your adventures
Rice Kellog still going strong Not sent from a SpyPhone with CrapApps etc
Old 15th June 2017, 02:31 PM   #8
DIYBras's Avatar
Default What low noise transistor?!
Here is the preamp schema.
Contrary to "common sense" when one don't have full knowledge about electronics like me, is that the lowest noise transistor need to be employed at input. Wrong. The second transistor/stage have higher gain in this design than the input, so I used the low noise 2SB486 in second stage, and more modest noise figure 2SB187 in input! Result: at least 10dB less noise than if one use the lowest .noise transistor in input and higher noise at second stage (output)...
This is measured in practice. What is going here in theory? Is about the stage gain I mentioned? Or stage impedance?
Old 15th June 2017, 02:46 PM   #9
DIYBras's Avatar
In 2011, I add a knowed trick in this amp output: a output current feedback, to lowering damping factor. With moderate Zi (like 2R), allied with the "finite" distortion, sounds like some tube amplifiers, but with irrestrict bass. (note the 0R12 and two 4R7 resistors network from load to feedback negative input)
This Ge amplifier here really "don't have the right to sound good as it sounds in reallity", ie. is a good sounding one.
Old 15th June 2017, 02:50 PM   #10
DIYBras's Avatar
The corrected schema, sorry...
Etude - Amplifier for study Patefon Tubes / Valves 4 9th August 2016 08:12 PM
New Amp on Study turnA_zpoint Solid State 0 7th March 2016 10:30 PM
Feasibility study 454Casull Multi-Way 10 22nd March 2009 12:23 AM
I want to study NoBit Digital Source 3 12th January 2008 02:35 PM
A study of current feedback digi01 Solid State 14 21st August 2006 12:01 AM
Copyright 1999-2017 diyAudio
