new Renardson amp
new Renardson amp
Old 24th March 2004, 05:15 AM   #1
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Default new Renardson amp
May I draw attention of the respected diyers to a new amp by Mr. Renardson
http://www.angelfire.com/ab3/mjramp/newamp2.html
The PCB will be available soon, if you need it, drop a note to Mr. Renardson
Old 24th March 2004, 05:34 AM   #2
dimitri's Avatar
Default another amp
And another amp based on the same principles from Czech
http://petrh.czweb.org/renardson.php
Old 24th March 2004, 08:05 PM   #3
PMA is offline PMA  Europe
PMA's Avatar
There is a cross-over distortion error correction in both schematics, listenning experience would be appreciated.
Old 27th March 2004, 09:49 AM   #4
dimitri's Avatar
I have simulated the output and would like to discuss it regardless of John Curl opinion:
”This fellow Renardson, is amazing! He re-invents all of audio circuitry, and then says that high power is not needed in the home”.
Old 27th March 2004, 09:54 AM   #5
dimitri's Avatar
Here are simulation results with R8 stepping from 100 to 1000 Ohm,
- transfer function of the output stage,
- current through nonswitching negative (lower) output device,
- transconductance of the output stage, please note the excellent linearity
Old 27th March 2004, 10:12 AM   #6
millwood is offline millwood  United States
Account Disabled
I am curious about it too, especially why R9/11/15 are set up that particular way.
Old 27th March 2004, 02:21 PM   #7
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
does any 1 know how this distortion correction works?
Old 27th March 2004, 03:13 PM   #8
dimitri's Avatar
dear milwood and sss,
you can read there
or I can send additional info to you
Old 27th March 2004, 06:34 PM   #9
PMA's Avatar
dimitri,
you are probably using MicroCap7. Have you tried harmonic analysis? I would like to know whether there are or not higher order harmonics, and of what value.
Pavel
Old 27th March 2004, 07:47 PM   #10
dimitri's Avatar
Sorry for my slip,
instead "current through nonswitching negative (lower) output device"
please read "current through nonswitching positive (upper) output device"
Pavel, yes, it is uC7, I have not tried harmonic analysis, don't trust simulators... But it is not a problem
new Renardson ampHide this!Advertise here!
MJR-7 Mosfet Amplifier of M. Renardson tryalx Solid State 65 14th May 2018 07:04 AM
Renardson email contact cs Solid State 3 9th February 2006 04:02 PM
