Speaker Protection Kit for under $5 - Page 2 - diyAudio
Old 16th June 2017, 12:18 PM   #11
xrk971 is offline xrk971  United States
xrk971's Avatar
Originally Posted by AndrewT View Post
the third 15k is across the "timing" capacitor.
That can ruin the timing to such an extent that the relay does not trigger.
In my view using a simple RC from an unregulated supply is a bad timer. Adding in the third resistor turns a bad timer into a worse one.
If you were to run the isolator from a regulated supply which then turns it into a resonable timer, then you find that the effect on timing of adding that third 15k is not as bad and can leave you with an effective way of "tuning" the delay period.
But I just miss it out and tune the delay by using a suitable value of plastic film capacitor where there is space to accomodate such.
Using an electrolytic REQUIRES one to slowly reform it to well above any voltage it may see in future operation. One of the biggest risks of using an unreformed electrolytic as the timer element in an unregulated arrangement is non triggering because the 15k and the electro draw so much "leakage current" that the timer NEVER triggers.
Finally before you try any of these unknown (no build guide) contraptions, it is incumbent on the user to first understand how it works. Then critically assess it's ability to do the job you the user requires.
It uses a 12v regulator - so is not unregulated. I agree an elfctrolytic is not best choice for critical timing.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 16th June 2017, 02:21 PM   #12
I like this uPC1237 protection because it does not require separate secondary for protection. It works from the power amp transformer, but you must make your own pcbs, there is no kit. I made 10 pcbs and the photo of one of these is attached
DIYfan: Speaker protection with uPC1237
Old 16th June 2017, 03:33 PM   #13
xrk971's Avatar
I don't use a secondary transformer for the 12v (or some people like 24v), just stick one of these cheap DC step down converters from your +ve rail (up to 35v) and you get an easy source to drive your protect circuit. If you are above 35v, you will need a different converter.
LM2596 DC-DC 4V-35V to 1.23V-30V Step Down Power Module Voltage Regulator 3A | eBay
Old 16th June 2017, 04:07 PM   #14
Very useful info. Didn't know that these little converters are available at such low price.
Old 16th June 2017, 04:24 PM   #15
thimios is offline thimios  Greece
I wonder how clean are the rails after adding this thing
Old 17th June 2017, 11:47 PM   #16
xrk971's Avatar
It's a passive connection via a relay so not sure how the circuit of this protection circuit would affect the power amp rails. Or do you mean connecting a DC to D.C. boost effect on the rail? I can measure when I get the next chance.
Old 17th June 2017, 11:53 PM   #17
JRKO's Avatar
Send a message via AIM to JRKO
Do these little guys protect against turn off thump? I have some compression drivers I'd rather not destroy
If I'm not making noise, I'm making something to make noise
Old 18th June 2017, 05:13 AM   #18
Exactly,is a switching regulator....
Old 18th June 2017, 06:21 AM   #19
Here is the seller's description in perfect Chinese English:
SKT Flyer Protection board
Features
The speaker protection board has the power delay (3 seconds) and DC protection (from the control voltage is about 1V) function, a simple circuit board, making easy, safe and reliable. With LED status display, when the protection light, the normal work time off. using 15A high current relay, suitable for the vast majority of amplifier board. Operating voltage AC 12-15V, requires a separate power supply.
After installation size: length 65mm x width 40mmx high 25mm . BTL circuit need two sets.
They don't mention loss of AC detection function.
Old 18th June 2017, 07:05 AM   #20
sajti is offline sajti  Hungary
I use separated small transformer for the speaker protection. I cost approx. 2Euro, and PCB mounted.
Sajti
Regarding the Velleman K4700U speaker protection kit cakyol Solid State 2 7th December 2014 01:44 AM
velleman K4700 speaker protection kit semmyroundel Parts 0 19th October 2014 11:47 AM
Problems with speaker protection kit shukamanon Solid State 3 28th December 2010 12:49 AM
Help with speaker protection kit julcat Solid State 3 21st January 2010 01:55 AM
HELP with kit: speaker protection and muting paulspencer Everything Else 0 7th September 2005 01:57 PM
Copyright ©1999-2017 diyAudio
