Speaker Protection Kit for under
Old 18th June 2017, 07:21 AM   #21
jacques antoine is offline jacques antoine  France
jacques antoine's Avatar
Originally Posted by sajti View Post
I use separated small transformer for the speaker protection. I cost approx. 2Euro, and PCB mounted.
Same here, adapted from a Buildaudioamps schematics.
Jacques
Old 18th June 2017, 07:38 AM   #22
Originally Posted by JRKO View Post
Do these little guys protect against turn off thump? I have some compression drivers I'd rather not destroy
delay to ON and instant OFF isolates the speaker before tha amplifier starts to shut down.
Instant OFF requires detection of the AC waveform and that loss of AC triggers the circuit.
This can be used for input mute of a Power Amplifier and can also be used as an output mute of a Source.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th June 2017, 08:34 AM   #23
sajti is offline sajti  Hungary
Or simply use the smallest possible capacitor in the protection PSU. I use 470uF only, followed by common 3 terminal regulator.
Sajti
Old 18th June 2017, 08:37 AM   #24
too slow.
regards Andrew T.
Old 18th June 2017, 10:21 AM   #25
thimios is online now thimios  Greece
Jacques
Can you share files,pcb and schematic?
Old 18th June 2017, 10:23 AM   #26
too slow.
No. It works well in practice.
Sajti
Old 18th June 2017, 10:29 AM   #27
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Not a universal solution. AC detection is the only way to be certain of the fastest possible off.
What came first, the music or the misery? Nick Hornby https://www.youtube.com/watch?v=nSlleE9s9gI
Old 18th June 2017, 10:34 AM   #28
No, but easy to adopt, and easy to try in practice.
Sajti
Old 18th June 2017, 10:39 AM   #29
Hi Thimios,
Other Audio Related Projects | BuildAudioAmps
For the BOM you have to subscribe (it's free).
Jacques
Old 18th June 2017, 10:47 AM   #30
silverprout is offline silverprout  France
silverprout's Avatar
too slow.
You should use very low Z relays without any capacitor after the rectifier.
PS : others should try to plug and unplug several times their boards to see what happened
Things You Should Have Learned In School (But Probably Didn't)
Speaker Protection Kit for under Hide this!Advertise here!
Regarding the Velleman K4700U speaker protection kit cakyol Solid State 2 7th December 2014 01:44 AM
velleman K4700 speaker protection kit semmyroundel Parts 0 19th October 2014 11:47 AM
Problems with speaker protection kit shukamanon Solid State 3 28th December 2010 12:49 AM
Help with speaker protection kit julcat Solid State 3 21st January 2010 01:55 AM
HELP with kit: speaker protection and muting paulspencer Everything Else 0 7th September 2005 01:57 PM
Copyright ©1999-2017 diyAudio
