SA2015 V-MOSFET  Builders
Old 22nd May 2017, 09:00 PM   #21
astx is online now astx  Austria
You could use silicon instead of your thermal grease too. You heatspreader is 10mm thick and is many times greater as your transistors surface.
Old 22nd May 2017, 09:12 PM   #22
thimios is offline thimios  Greece
Thanks Toni,i have thermal paste on hand but i see silicone pads 0.5mm or 1mm thickness that would be more ideal.
Old 23rd May 2017, 08:59 PM   #23
My plan is for two holes drilling in the heatspreader ,one 5mm hole for the vbe transistor and one 3,5mm for the led.
Is this a good solution?
Old 23rd May 2017, 09:27 PM   #24
Of course a possibility: 2-3 mm deep hole should be enough. Fill it with a little bit thermal grease. Or just add a squishy spacer between pcb and BC550C as AndrewT has done.
The red LED need not to be in direct thermal contact with the heatsink - only between pcb and heatspreader.
BR, Toni
Old 25th May 2017, 11:45 AM   #25
I hope that is ok now...
A little cleaning around and ready to pcb mounting.
Old 25th May 2017, 11:49 AM   #26
I'm sure it will do its coooooling!
Old 25th May 2017, 01:31 PM   #27
The heat spreader drilled using 6mm drill for the center and 10mm for the top.
The heatsink drilled using 3.5mm then 4mm and tapped with a 5mm, sharpened to the lower end,tapping tool.
Screws are 5x12mm inox .
All parts cleaned using dish washer liquid for tapping fluid removing.
After drying a plenty of thermal paste applied
Aluminum was pressed as in the picture to reduce the gaps to the minimum.
Finally the screws tightened.
Old 26th May 2017, 12:55 PM   #28
Default SA2015 in progress
Boards mounted in the final position then tested again,no surprises.
Old 26th May 2017, 01:22 PM   #29
Project16 is offline Project16  France
Project16's Avatar
Hello Thimios
I see that you have positioned the plate with the holes as I told you. With this layout you will not have to drill the bottom of the case, just for the feet.
Congratulations for your work and I think you will really have no problem with heat dissipation.
Regard's
Old 26th May 2017, 01:45 PM   #30
Perfect cooling!
BR, Toni
SA2015 V-MOSFET  BuildersHide this!Advertise here!
still any Aleph-X builders here? anotherJoachim Pass Labs 30 23rd June 2017 08:48 PM
simple quasi complimentary MOSFET amplifier BUILDERS GUIDE meanman1964 Solid State 37 22nd November 2016 02:43 PM
Your own builders book pitchwest Tubes / Valves 0 31st May 2013 05:16 PM
Hello builders! djpenguin Introductions 1 1st April 2010 04:35 AM
Class A mosfet amp builders in Queensland Australia? gregjpeters Pass Labs 3 6th November 2002 10:46 PM
Copyright ©1999-2017 diyAudio
