Old 23rd March 2004, 07:24 PM   #1
tab30 is offline tab30  Germany
Default RMS Power
I tried to calculate the RMS-Power of an amp at given DC-Driver voltage.
But I always get higher values than in the description of the (DIY) amp is given.
Well reasonable I must reduce the output Umax by the "Saturation" voltage of the amp but I don't think that an 400W amp working with 70V only give out 56 V.
I added my calculations.
This Probelm hounded me the last day's I hope someone can help.
Andi
Old 23rd March 2004, 07:40 PM   #2
Thoru is offline Thoru  Netherlands
#1 is correct, #2 is not. RMS means 'root mean square' and you ommit the root.
I don't know what you mean with #3 nor the rest, but perhaps that adding that root solves your problem.
If I remember correctly than the Vrms of a sinus is 1/2*sqrt(2)*sin(x), and you can than square that voltage, divided by the number of Ohms should give you the output power.
Remco Poelstra
Old 23rd March 2004, 08:22 PM   #3
In #1
I mean not U=Umax I mean U=Urms
now you get #3 with Urms=Umax*1/sqr(2)
sin(x)*Umax is the voltage at the "angel" 0-360 deg respectively 0-2pi.
After the first equation I have to square the voltage -> (sin(x)*Umax)² and divide it with the impendance r.
now I add all pieces Power together and divide it with 2pi.
right ?
The Education should be right ? !
Old 23rd March 2004, 08:32 PM   #4
Simple fact is you are disregarding losses in the amplifier,
power supply average voltage droop and the the extra
ripple below the average voltage droop.
You cannot estimate 4 ohm output power from nominal rail voltage.
(nor 8 ohms for that matter but its nearer)
What you can do is estimate losses for 8 ohms max power,
which again will be lower than predicted by rail voltages
and double them for 4 ohms.
sreten.
Old 23rd March 2004, 08:51 PM   #5
It is correct for the most part, but #2 is wrong. It should be something like the image below. But that boils down to P=Vrms over r if I'm correct.
That for the math part.
Remco Poelstra
Old 23rd March 2004, 08:52 PM   #6
there is no way to estimate the Power of an amp, before you have measured it ?
Isn't it possible to calculate/ name circa values for all the loss that occur ?
and take that in the estimation.
Well,
if I use a verry good/ powerfull supply, with big capacitances.
What loss will occur except the Saturation and some mV in the connection lines ?
Old 23rd March 2004, 08:57 PM   #7
Class B amp's only have a efficiency of +-60% no matter what powersupply or wires you use, it's just the way they are build. Class A gets closer to 30%. Thus for every Watt you put in you'll only get 0.6 Watt back. 612*0.6=367 which is close to enough to 400 to rate the amp at 400 I think, taking into consideration that the calculations are very rough.
Remco Poelstra
Old 23rd March 2004, 08:59 PM   #8
@ Thoru
but with this education you get much lower values as given in the DIY-Amps.
And I thik my solution should be right because you get the same as you get if you use #1 and Urms=Umax*1/sqr(2)
Old 23rd March 2004, 09:01 PM   #9
Well,
A perfect supply is hardly the point.
You want output with a sensible cost effective supply.
And yes intelligent estimations can be made.
But they are not based on nominal no load rail voltage.
sreten.
Old 23rd March 2004, 09:03 PM   #10
@ Thoru second message
But the efficiency of 60% means only you need an PowSup witch delivers 1,6 * (Pwanted out)
isn't it so ?
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Page generated in 0.21738 seconds (40.28% PHP - 59.72% MySQL) with 11 queries
