#2651 |
you need to know what the starting value of each variable resistor needs to be, to allow a safe (undamaging) start up.
#2652 | |
I have the same kit from Siliconray that I bought sometime ago and am still working on it. I noticed that the 3 trim pots (VR1 VR2 and VR3) that you used are different from mine. Did you buy the whole kit or did you just get the board? In my kit, the pots can only go in one way and they fit the outline on the board exactly. Regards, Lo_Tse |
#2653 |
Hi
What values of resistor have you got for the input bias adjuster (would this be VR1?). If I add up the currents there is roughly 350 uA in the input transistor plus a bias across the 2.7k feedback resistor which will be another 250uA or so, totalling 600uA in the first stage bias. Therefore you should have a resistor of about 1k which suggests we need a variable of about 2.2k and a series limiting value of maybe 220 ohms. On the other hand if the feedback decoupling capacitor is eliminated (feedback grounding resistor connected directly to ground) then 10 times more current is needed. Is it that the input resistor-variable resistor is mismatched to the circuit (i.e. values for no capacitor used with a decoupling capacitor?) CHeers John |
#2654 |
Lo & John. Thanks for your replies. I need to get my head around this, so will check the values. Lo, I just got the bare board and provided the components myself.
Rob. |
#2655 |
The BOM specified these values -
VR1 200 VR 250 VR3 20k |
#2656 |
The problem I see is this: using the Siliconray drawing of JLH's 2005 amplifier (and just how are the components labelled?- I normally start with R1, Tr1 on the left and work left-to-right, top-to-bottom) VR1 sets the current in the input transistor. Its emitter voltage should be around +.7V because the base is tied to ground through bias resistors R2,R3). If C3 is included, the current flowing in R8 (feedback resistor) is about 250uA or so. The current flowing in the first stage transistor (I'd call this Tr1, not Q4, and redraw the circuit so that Q5 and Q6 were a little more to the right!) is about 150uA, plus whatever base current is needed by Q3. Therefore the emitter resistor of Q6 should be about 0.65/.45mA or 1.4k. If C3 is omitted (shorted) then R6 conducts about 3mA, making the sum of R13 plus VR1 about 200 ohms. It is unclear what VR3 does but might be used to provide some sort of temperature compensation.
HOwever, on second thoughts, my proposal that if you use C3 wiht component values as given (VR1=200) then the output voltage will be about -7V not +7V. IS this the case? If not then I suspect that a transistor may be wrong (7V is a zener voltage of a reversed base-emitter junction). Have you inadvertently used a BD139 where Q8 should have a BD140 or something? In any case, you have a choice. Either remove C3 (and replace with a jumper wire) or replace R13 with a 220 ohm and VR1 with a 2.2k pot. Siliconray or whoever should have pointed this "howler" out. C3 might be optional but needs different resistors. Cheers John |
#2657 |
#2658 |
#2659 | |
Rob. |
#2660 |
UPDATE :
I removed C3 (after having checked the values of VR1, 2 & 3 as I had not in fact checked them before installing ) they were fine. Fired it up and started to adjust the DC offset (no speakers within 100 miles)Got it down to 0 and attached speakers. Offset seems to drift, but nothing more than 50mv. Is it a matter of continually adjusting or where is it best advised to leave it? A big thank you to John_ellis for his advice. Rob. |
| 20 Watt Class A amplifier | JOE DIRT® | Solid State | 8 | 31st January 2012 11:41 PM |
| JLH 10 Watt class A amplifier | DomKo | Solid State | 3 | 18th November 2003 06:32 AM |
