JLH 10 Watt class A amplifier
Old 14th November 2012, 09:01 AM   #2621
deduikertjes is offline deduikertjes  Netherlands
deduikertjes's Avatar
I figured I should start to work with 2n3055 (as they are cheap) and when the circuit is debugged and stable, to upgrade it to MJ15003 as most people recommend it.
Small warning:
I did something like that too. But with my relatively high rail voltages (about + and minus 20V) the Toshiba's 2n3055 where just outside their SOA. One channel repeatedly died on me.
After changing to the new transistors overything is ok.
MArco
Old 14th November 2012, 10:40 AM   #2622
Mooly's Avatar
Originally Posted by deduikertjes View Post
Small warning:
MArco
Perhaps they weren't genuine devices. 40 volts and a couple of amps (which is more than the JLH runs at) is well within a 2N3055's abilities as long as it is cooled sufficiently.
Old 14th November 2012, 12:53 PM   #2623
AC439 is offline AC439  United States
Small warning:
..... (about + and minus 20V) the Toshiba's 2n3055 where just outside their SOA. One channel repeatedly died on me.
MArco
I also first started with Toshiba 2n3055 bought from the "_bay" for prototype thinking they were fake. I paid $1/piece. But to my surprise, they did not sound bad at all. I ran them at +/- 25v for quite a while before changing them to MJ15003. The upgrade was a direct swap and no adjustment was needed.
Old 14th November 2012, 03:26 PM   #2624
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default Huh ?
Is something wrong with the siliconray PCB's ?
Old 14th November 2012, 04:13 PM   #2625
haiduc32 is offline haiduc32
Jaap, if you're concerned by the discussions around the siliconray pcbs that I've started, it's just that it's my first diy amp, so I managed to fry it when I first powered it, and then after powering it second time.. and then after short circuiting some transistor with the test probe.. . no reasons to panic. I'll receive the replacement transistors tomorrow (or so I hope), and come back with the results, of more questions..
Old 14th November 2012, 05:58 PM   #2626
There is a discussion on their board. Error was mentioned but seems like was fixed in later version of the board:-
★★ Free PCB for JLH 2005 Class-A Amplifier
I don't use their board so I cannot verify this.
Old 16th November 2012, 01:46 PM   #2627
Geoff is offline Geoff  United Kingdom
Good news! TCAAS is now back on-line. It is being hosted by ESP (many thanks Rod) and can be accessed using the following link:
The Class-A Amplifier Site
or via the ESP index page (it's in the 'Articles & Information' section):
Elliott Sound Products - The Audio Pages (Main Index)
Old 16th November 2012, 02:12 PM   #2628
Telstar is offline Telstar  Italy
Thanks Rod!
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 16th November 2012, 04:26 PM   #2629
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
an aside. I used Bourns TIP3055 in Rod Elliots P3 amp with +/- 42V rails with no issue. At least none I was aware of. They worked much better than the SMI types i trialled breifly, but even those didnt fail.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 16th November 2012, 11:30 PM   #2630
paulb is offline paulb  Canada
Good news indeed, and good to see your name here again Geoff! Time to dust off my JLH and put it back in service.
JLH 10 Watt class A amplifierHide this!Advertise here!
20 Watt Class A amplifier JOE DIRTŪ Solid State 8 31st January 2012 11:41 PM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 06:32 AM
