#2571 |
#2572 |
The choke you show is a macro shot of a rather small common mode choke - probably height about 50mm total.
If I was building valve amps I would try a resistor in series with a small choke
#2573 | |
Probably one of the most approachable articles is Input Choke & Resonant Choke Power Supplies for RF Linear Amplifiers (by Tony IØJX & Pesa IKØHIT) If you do the math you'll find you don't need much inductance for deep Class A sand amps as long as the core is big enough not to be completely saturated: a 12VAC or there abouts secondary EI transformer of about the same size as your mains transformer will likely be in the right ball park. Try it and measure the results. Last edited by thoglette; 22nd September 2012 at 04:14 PM. |
#2575 |
#2576 |
Thanks for the comments!
#2577 | |
Even a full wave rectifier/split rail solution would end up with DC in the core. I think?! |
#2578 |
What case ? I thought he wanted a choke for a tube amp but I have not seen the schematic so I cannot comment about any case . . . .
Just saying if you using this common mode choke as intended the DC currents cancel and that's why the core can be so tiny for such large currents. As it was not intended for a tube design it might not be very relevant to the "case" whatever it might be |
#2579 |
#2580 |
Yes, and a choke instead of a resistor in a power supply with a capacitor-resistor (or choke)-capacitor.
| 20 Watt Class A amplifier | JOE DIRT® | Solid State | 8 | 31st January 2012 11:41 PM |
| JLH 10 Watt class A amplifier | DomKo | Solid State | 3 | 18th November 2003 06:32 AM |
