JLH 10 Watt class A amplifier - Page 151 - diyAudio
Old 5th January 2007, 12:43 PM   #1501
paulb is offline paulb  Canada
Hi Geoff, your post arrived as I was composing mine. Thanks for the enlightenment.
I should note that I had no problems whatsoever with oscillation or bias stability (following Geoff's bias adjustment recommendations). The power supply for this amp was much more difficult, actually, as I chose to parallel two power transformer outputs with their primaries wired in series (to use transformers I had on hand).
Old 5th January 2007, 01:13 PM   #1502
united is offline united  England
Thanks Geoff and Paul for your clear and concise replies. It seems that the high power version would be a better option as it seems to be less stressful on the output transistors. The 3055s on the 1996 jlh I built gave up the ghost too often.
The pcbs I have are from Williams Hart and are of poor quality, does anyone know of a supplier of pcbs of the layout you recommend? Also for the cap mult circuit. I have no way of making pcbs.
Jeremy
Old 5th January 2007, 01:44 PM   #1503
I ordered mine from Olimex and am quite pleased with the results. If you need help to submit the Gerber files to them you can email me directly.
http://www.olimex.com/pcb/protos.html
Old 5th January 2007, 05:25 PM   #1504
MikeW is offline MikeW  United States
MikeW's Avatar
Originally posted by paulb
Congratulations! Enjoy!
I've placed all the new information I received from Geoff (schematics, layouts, gerbers, etc.) on my personal webspace at
http://members.shaw.ca/paul.r.brown/...%20Moss%20JLH/
This is the same stuff I posted individually here a few pages ago. Geoff is still planning to update his site but hasn't got to it yet.
Are the output transistors mounted off the board. If they are mounted to the board the pin outs are wrong. It should be B C E.
MikeW
Old 5th January 2007, 06:29 PM   #1505
Geoff is offline Geoff  United Kingdom
Mike
The layout was done for output transistors that are not mounted on the board. The pads and holes are sized to suit 5mm pcb terminal blocks so that (short) flying leads can be taken to both TO-3 and flatpack transistors. This gives greater flexibility for alternative heatsink types and keeps the pcb, and board mounted components, a little further away from the hot heatsink surface. It also meant that a virtually identical layout could be used for both single and double sided boards, with the need for only one jumper on the single sided pcb.
Geoff
Old 5th January 2007, 06:53 PM   #1506
MikeW's Avatar
Thanks. Hope you are doing well. My JLH is still sounding goood.
MikeW
Old 6th January 2007, 11:32 AM   #1507
Thanks for the link Paul.
Does anyone know of something similar over here in the uk?
Also, where can I obtain tantalum film resistors or vishay? How about the exotic paper in oil caps?
Sorry to seem such an ignoramus but it's been years since my last diy fling. It was the days of Farnell having an actual catalogue which they sent me!
J
Old 6th January 2007, 11:44 AM   #1508
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
J
They still have a catalogue - but their CD catalogue is very well done and easy to use and most times i prefered* to use this. ( as opposed to their website which is not that great )
*past tense because I now live in the US.
Old 6th January 2007, 11:49 AM   #1509
Olimex is closer to you than me, they're in Bulgaria.
Old 6th January 2007, 12:23 PM   #1510
Oops, I saw the pricing in $ and jumped to the wrong conclusion. I'll send you an email so you can give me a few pointers on how to place an order. Thanks yet again.
J
20 Watt Class A amplifier JOE DIRT® Solid State 8 31st January 2012 11:41 PM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 06:32 AM
Copyright ©1999-2017 diyAudio
