JLH 10 Watt class A amplifier
Old 6th October 2002, 06:55 PM   #131
chris ma is offline chris ma  Canada
chris ma's Avatar
Default Back side of things
The LEDs of the Velleman K4700 dc-protection, a muting switch and a Iq current setting test plug.
Old 6th October 2002, 07:16 PM   #132
tschrama is offline tschrama  Netherlands
Waauuuwww ...greeeaattt .. that looks massive! What transistors are you using... are you really using that high Iq?
happy listening,
Thijs
Old 6th October 2002, 10:57 PM   #133
chris ma's Avatar
Thijs,
I use 4 MJ15003 in the amp and 2 LM338K in the PSU. The voltage drop across R9 is 194mV so I say it is close to 4 amps, and the amp is so stable I get 00.5 displayed on my multi-meter set at 200mV on the dial when test for the DC offset. The switch on DC offset is around 480mV and start trimming right away. It does take an hour to get down to 0.5mV though. It did not sound as good when bias setting is lower.
Old 7th October 2002, 03:14 AM   #134
chris ma's Avatar
Folks,
Sorry about the picture quality, I borrowed my 7 years old nephew's $60 digital camera to play with. And also the fact that I was a bit shakey when taking the shots due to lack of pints for my daily doses.
Old 7th October 2002, 03:36 AM   #135
NickC is offline NickC
what's transformer size you guys recommend for 4amps at 20 volts. is 250va 18 volt good enough.
is there much difference in sound when comparing regulated supply with 30000uf and the regulator with pi-filter(
22000uf - 15mh-144000uf)
when running at 4 amps won't the sinks be hot. The ratings for your sink is 0.5 rite. I used the same amount, 4 transistor on 4 sinks each 0.5 rating the temperature reaches 57 celcius at 22 volts at 2.2 amps. i was wondering to upgrade it to 4 amp soon so just wondering on the need for more sinks.
Old 7th October 2002, 03:56 AM   #136
chris ma's Avatar
The transformer I am using is Piltron 300VA 18-0-18, it gets rather hot after an hour or so the metal mounting disc of the transformer is too hot even to touch, the heat sinks are fine though, I can touch them for a long while without feeling uncomfortable. But I have no means to measure the temperature of the heatsink, actually my wife suggested that I should try to see whether it can make toast for her by place a slice of bread on top of each heatsink.
I am also interested to see what result/difference you may experience with the pi-filter too. My experience with more caps results in stronger bass but loses dynamic and air of the highs.
Old 7th October 2002, 02:42 PM   #137
to test the the temperature using your fingers
bewarn keep a burn kit nearby
if the sink is to hot to touch 65 and above, u can't differentiate between 65 and 100 degress respond of the fingers will be faster the time taken for the finger's heat sensors to respond
if the sink is hot but the your hand is able to rest on it for a while, means temperature is less than 65 but more than 50
and i don't think we need to go more than that. class A should idle at 60 degrees to maximise heatsink cost
for more temperature ranges, u got to work at starbucks (steaming milk)
that why i can guess the temp with some tolerance plus i have a thermometer for food.
from your description the tranies at above 65. How fast does your hand respond by pulling away. Normally i guess the transformer can be run at almost maximum capacity with no much problem just less life for the tranies
but sinks are 50 to 57 should be okay
Old 8th October 2002, 11:49 AM   #138
boessenkool is offline boessenkool
Default voltage at minus side output cap
I've build the JLH 10W (1969) version as described in the 1996 article. (4 channels, 4 transformers, 4 bridges etc, 1 casing).
(figure 1 in http://www.gmweb.btinternet.co.uk/jlh1996.htm)
So far progress is slow but steady. (Thanks again to Geoff for the earthing problem.)
But I've encounterd the following problem and I was hoping for some help.
Last night when I finally was able to bi-amp the loudspeakers, everything seemed to be allright. Bi-amping sounds even better than normal amping.
But............, the sound from the right channel has a strange scratching, resonating component.
The only strange thing that I can find, is that the output (minus) side of the output cap has about 14V, seems to me that this shouldn't be so. (I expected 0V) I don’t know what causes this.
I have neglected to put a 1K resistor, after the ouput cap and earth, but can this be the problem or is it something else?
Luuk Boessenkool
Old 8th October 2002, 05:03 PM   #139
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default To boessenkool
hei boessengkool !
If you have 14 volts at the minus side of the output capacitor with the speaker conected...you a have a short in the capacitor and maybe a burned speaker!!!...
If the 14 volts reading is without the speaker conected is because, as you dont have put the 1k resistor the capacitor d'ont have a path to ground for charging...in this case everithing is fine...
Put the 1k resistor and measure again...
Jorge Santos
Old 9th October 2002, 05:30 AM   #140
Default Hei Santos !
Jorge,
I did have 14V at the speakers, but nothing happened.
Goes to show how good Dynaudio really is, it's a pity that the don't sell their components anymore.
I did put in the 1K resistor and indeed everything is ok now.
It is truly amazing what bi-amping can do. And that with an amplifier design from 1969.
Next stage for me: active crossover.
Luuk Boessenkool
JLH 10 Watt class A amplifierHide this!Advertise here!
20 Watt Class A amplifier JOE DIRT® Solid State 8 31st January 2012 11:41 PM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 06:32 AM
