JLH 10 Watt class A amplifier
Old 7th November 2004, 12:16 AM   #1021
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Default Re: preset calculation
Originally posted by numbernine
Mikelm: I wdispositions. Merci beaucoup.
I just discovered that constantan resistance wire sounds MUCH better than thick film resistors
28swg is about 4.2 ohms per meter
http://www.diyaudio.com/forums/showt...054#post507054
http://www.wires.co.uk/acatalog/COPPER_NICKEL.html
Mills noninductive wire wound are also good apparently but I have not heard them and they are much more expensive
mike
Old 7th November 2004, 03:05 AM   #1022
chris ma is offline chris ma  Canada
chris ma's Avatar
Originally posted by dutch diy
Chris,
At what rail voltage and bias current were you operating?
I'm running for over a year now on 29.5V and 2.2 A on 4 mj15003's.
During testing of my first J-amp set my Shack Speaker however survived several + an - 22 V DC-offset problems, and not for milli seconds i can tell.
For those two years they were set at 20V and 4A and the heatsinks were measured at 55 Celius with no problem. That day when it happened I was listening to them for about an hour or so and I fell to sleep. When the CD ended I woke up and change the CD then I noticed the DC Protection light came on. So I had no idea how long it had happened. I am not sure whether it would have done some sort of damage to the JX150 or not if there was no DC protection. Now I reduced the Iq setting to 20V, 3A to all four mono block JLH.
All heat sinks measured at 41Celius. As I am bi-amping I do not hear much difference whether it is set at 4A or 3A. Before bi-amping 4A sound better than 3A.
Chris
Old 7th November 2004, 03:02 PM   #1023
eLarson is offline eLarson  United States
eLarson's Avatar
Default Re: Re: preset calculation
What are you using it for?
Erik
Would a woodchuck bother to chuck MDF?
Old 7th November 2004, 03:41 PM   #1024
I just noticed that the some of the quote was missing so the post was not as clear as I intended
I am currently using constantan wire as an emitter degeneration resistor 0.1 ohms on the o/p transistor ( the bottom one ).
I was using a thick film resistor before.
The difference in quality is quite dramatic.
( The effect was similar when I swapped out a 0.5 ohm caddock in a cross-over )
mike
Old 7th November 2004, 03:44 PM   #1025
eLarson's Avatar
Just a straight piece, about 2 cm or so long? Or wound 'round something? Do tell, do tell.
E.
Old 7th November 2004, 03:58 PM   #1026
The reel of wire that I have is 28 gauge and this gives about 4.2 ohms per meter
a range of gauges can be found here
http://www.wires.co.uk/acatalog/cn_wire.html
4.2 ohms per meter = 0.1 ohms per inch ( 25mm )
How you implememnt this rather depends upon you method of construction. either mount it on blank vero using posts or just put 25mm across whatever gap you have. I would not wind or coil these as this will create inductance.
If you do not already have emitter degeneration resistors you may have to re-adjust you bias current depending of the cct you are using.
I will be interested to hear what you think of this mod
mike
Old 9th November 2004, 08:07 AM   #1027
bremen nacht is offline bremen nacht  Europe
Default Resistance wire
mike
Maplin also sell it in smaller quantities (an ounce for a fiver - how many ohms per ounce, I wonder?). I'll give it a go.
Old 9th November 2004, 09:01 AM   #1028
Jonathan Bright is offline Jonathan Bright  Australia
I just want to make a small contribution to the use of "resistance wire". In fact it is actually possible to wind wire in a non-inductive way. This may be useful where it is not possible to find a home for the length of wire you have to use and still mange to keep it in a straight line. It saves space and is quite elegant in its use of physical principles. The only place I know that shows this technique clearly is contained in Geoff Moss's Class-A site. I guess most uses of this thread know Geoff's site. If you go there and then select "Other Class A amps" you will find the Nelson-Jones 10 Watt design. Choose the "article" (not the schematic) link and go to page 12 (of 14). There you will find a delightful diagram of a 0.56 Ohm 5% resistor wound "non-inductively".
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 9th November 2004, 12:38 PM   #1029
Geoff is offline Geoff  United Kingdom
To save anyone interested some time, I have attached the relevant figure.
Old 9th November 2004, 02:54 PM   #1030
Upupa Epops is offline Upupa Epops  Czech Republic
This type of resistors are made by industry too.
JLH 10 Watt class A amplifierHide this!Advertise here!
20 Watt Class A amplifier JOE DIRTŪ Solid State 8 31st January 2012 11:41 PM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 06:32 AM
