JLH 10 Watt class A amplifier - Page 100 - diyAudio
Old 5th October 2004, 06:27 AM   #991
ralf is offline ralf  Germany
Default hum...
thanx,
Ralf
Old 9th October 2004, 09:54 AM   #992
Tyimo is offline Tyimo  Hungary
Default TO220 and TO247
Hi!
Could somebody to suggest me a good and NOT in TO3 case transistor substitute instead of the MJ15003? For my design the TO220 or the TO247 would be better.
Thanks!
Tyimo
Old 9th October 2004, 02:29 PM   #993
EUVL is offline EUVL  Europe
Default Not TO3 Transistor
Well there is always the TIP3055, as long as you don't burn too much power with it.
No, I have not tried it before, so no guarantee of quality of sound. But I imagine it should not be too different from the original 2N3055.
Patrick
Old 9th October 2004, 03:30 PM   #994
AX816 is offline AX816  Romania
Send a message via MSN to AX816 Send a message via Yahoo to AX816
Bi,not TO3 ...as i posted early there a a bunch of transistors that can fit in your requests.I onestly recommend u the Sanken transistors using them will guaranty your satisfaction...at least mine did.Anyway take care and watch out for the fake ones.
http://www.ampslab.com/components.htm
Old 10th October 2004, 11:18 AM   #995
Thanks!
I would try the 2SC5200 or 2SC3281, if there is not any stability problem. Is there?
Greets:
Tyimo
Old 15th October 2004, 12:27 AM   #996
Default jlh amp newby
Can I build this amp from using only the schematic on page 11 fig 3 The high power circuit? And if so what are the values of r14, r16,r15,r13,.
Thanks. Steve
Old 15th October 2004, 02:28 AM   #997
chris ma's Avatar
Default Re: jlh amp newby
Thanks. Steve
Hi Steve,
Fig 3 – The Higher Power Circuit
100m = 0R1
I used 4 x ohmite 25W 0R1 power resistors for the current amps and 4 x Caddocks for the older amps. Can not tell the difference bewteen the two brands
Chris
Old 15th October 2004, 03:07 AM   #998
Is this 100 meg ?
Thanks steve
Old 15th October 2004, 06:03 AM   #999
Dragance007's Avatar
Send a message via ICQ to Dragance007
Smile LE
Since this thread is about to go over 1000 post, i belive i should build one 10w bjt version.
Proud owner of prototipe jlh 10w mosfet version discussed here
good day from serbia
Old 15th October 2004, 06:30 AM   #1000
JRKO's Avatar
Send a message via AIM to JRKO
Default Whew
Just finished reading this WHOLE thread. Cant see straight!
Well thats 1000 so I'm gonna build one as well!!!
If I'm not making noise, I'm making something to make noise
20 Watt Class A amplifier JOE DIRT® Solid State 8 31st January 2012 11:41 PM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 06:32 AM
Copyright ©1999-2017 diyAudio
