Hi all,
what do you think of this? I haven't seen this topology anywhere. Am I missing something or is this a great way to overcome limitations of JFET switches: - no current actually passes the JFET. It is just used as a switch passing voltage to the inverting op amp input - the inv input being essentially a voltage sensor anyway and not a load - R(DS) should therefore remain constant - any minor variations in R(DS) will be insubstantial compared to the input impedance of the op amp. Potential for problems would be - nonlinearity for bipolar voltages - however at virtual ground there won't even ever be any V(DS) *or* I(DS) - leakage of control voltage of the JFET - however, again, at virtual ground on one end and "infinite" input impedance on the other that shouldn't be a problem. Have a found the elusive non-distorting JFET switch application? MBK |
#2 |
up
MC_Wilson |
#3 |
hey thanks, I thought I'd never get any interest from the forum for the stuff *I* think is interesting
MBK |
#4 |
Nonlinearity would be my concern too. Isn't that the basic problem with commercial analog switches?
Also be aware that the drain-source capacitance of FET's goes way up when there's no DC voltage on them. Try it and report back.
dave |
#5 |
... with 2 stages (not the full R ladder), one JFET "on", the other "off", and a TL072. Didn't listen, but did distortion tests. My soundcard is not the greatest I'm afraid, but at least I see no difference between just resistors, and resistors plus the switch. Photos of distortion spectra below. The source was test CD's with either sine waves (250 and 1000 Hz) or a 200 Hz sine wave modulated tone burst (Linkwitz test CD). The sine measurements show distortion which is equal to the passive R setup and the JFET setup; this may have come from the source recording or another limiting factor. The burst spectra are cleaner. The noise floor especially below 200 Hz mocks things up a little. Regardless - I see no difference at this stage and with this equipment, between passive resistor divider on the inv input, or a JFET switch.
MBK |
#6 |
200 Hz burst passive
#7 |
200 Hz burst JFET
#8 |
250 Hz sine JFET
#9 |
1000 Hz sine passive
#10 |
1000 Hz sine JFET
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| single JFET as volume control | Leolabs | Solid State | 1 | 13th December 2005 03:59 AM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Page generated in 0.15677 seconds (51.97% PHP - 48.03% MySQL) with 11 queries |
