are both these bridge recitfier ground loop breakers the same?
Old 21st April 2017, 11:22 AM   #1
ctrlx is offline ctrlx  United Kingdom
Default are both these bridge recitfier ground loop breakers the same?
Old 21st April 2017, 11:46 AM   #2
Ketje is offline Ketje  Belgium
Ketje's Avatar
The first one allows 1.2V max beween house and chassis, the second one only 0.6V.
Mona
Old 21st April 2017, 04:16 PM   #3
The left drawing is wrong.
It shows the Diode Bridge between the House Ground and the Chassis Ground.
One MUST NEVER put anything into the Protective Earth link from Chassis to the PE wire.
The PE wire MUST be directly connected to the Chassis. There are no exceptions.
The Disconnecting Network (DN) if required goes into the link from Audio Ground to the Chassis.
This is usually not required in a mono block amplifier.
It is sometimes unnecessary in the two channel amplifier, but most multi-channel amplifiers seem to require the DN to attenuate interference current crippling the Hum performance after connecting source equipment.
regards Andrew T.
Old 21st April 2017, 04:21 PM   #4
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
+ left is series, right is parallel wiring of the diodes, so twice the current handling. Left is so wrong it's scary
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 21st April 2017, 07:42 PM   #5
Ketje's Avatar
Looks like this.
I like he left one
Mona
Old 21st April 2017, 07:45 PM   #6
Ha ha, whatever the drawer has done there trying to help has had the opposite effect on my brain! I'm worried in the left one what happens in the middle?
Old 21st April 2017, 07:47 PM   #7
Ketje's Avatar
Even more confused ?
Mona
Old 21st April 2017, 07:55 PM   #8
Gusser is offline Gusser  United States
Just note that these ground lifters are not found in any commercial gear. Certainly not in any gear with a UL or other authorized safety certification.
If the device is engineered properly, this is totally unnecessary. It's a hobbyist hack and a dangerous one at that as it is often done improperly.
Old 21st April 2017, 08:05 PM   #9
Ketje's Avatar
You could be right.Better do it like this, but with diodes up to the task i think there is no problem.
Mona
Old 21st April 2017, 08:11 PM   #10
It can be done safely I believe, as many do
are both these bridge recitfier ground loop breakers the same?Hide this!Advertise here!
Question Re: Ground Loop Breakers Magz Tubes / Valves 15 24th March 2014 12:44 PM
What needs grounding on LM3886, and what voltage bridge rectifier for ground loop semmyroundel Chip Amps 16 17th February 2014 10:11 PM
Loop breakers felixx Solid State 55 3rd March 2008 09:44 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Bridge Rectifier Ground loop fix (seen in Zenv4) cmcgraw Pass Labs 3 24th February 2003 05:47 PM
Copyright ©1999-2017 diyAudio
