Build NAC 42 single end preamp - diyAudio
Old 18th April 2017, 08:02 AM   #1
Default Build NAC 42 single end preamp
Hello,
I want to build a nac 42 preamp clone and search for a circuit with mods,
can somebody help me to find it?
Pls with a description of the right capacitors, which are the best for the circuit.
A other question I search for the transistors ZTX384/214 and it's not possible to find it, which transistors can I use also to replace the ZTX?
Thanks in advance
Old 18th April 2017, 08:39 AM   #2
Sure thats easy.
Start your search here.
Old 18th April 2017, 08:44 AM   #3
JonSnell Electronic's Avatar
ZTX384/214
BC550/560 might be a suitable replacement. Correct or better parameters and correct pin outs
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 18th April 2017, 09:23 AM   #4
Originally Posted by JonSnell Electronic View Post
ZTX384/214
Thanks!
I will take this both.
But I see there are existing BC560/550 and BC560C/BC550C, can I also take this both?
Old 18th April 2017, 10:11 AM   #5
Originally Posted by dsch View Post
Thanks!
I found that the 3 versions of the BC550/560 (ABC) has a different value
A: min 125 max 260
B: min 240 max 500
C: min 450 max 900
Which one is the best in my case for the NAC42 ?
Old 18th April 2017, 04:15 PM   #6
I have here some 2SD667/2SD647 can I also use this for the preamp?
Old 18th April 2017, 05:00 PM   #7
.... 2SD667/2SD647 can I also use this for the preamp?
These high voltage drivers are better suited for use in the power amplifier VAS, rather than low level circuits. That's not to say they won't work at all but the types already suggested will be better in the NAC preamp design.
If you search in the right places, you'll see that "C" grade parts are specified; http://www.acoustica.org.uk/ then navigate to More Naim stuff/The Naim DIY preamp mods bible.
Ian
Old 18th April 2017, 05:27 PM   #8
If you search in the right places, you'll see that "C" grade parts are specified; Just one thing about music - when it hits you feel no pain then navigate to More Naim stuff/The Naim DIY preamp mods bible.
Hi Ian,
I can find only the BC550/560 but not index "C".
Is the BC550C and BC560C the right choice and the best choice?
Old 18th April 2017, 06:09 PM   #9
At the specified supply voltage of 24V, BC549C/559C (if available) would probably work fine too. You don't show us where you live so it's pointless trying to suggest where you should be looking to buy components. However, as obsolete, through-hole transistors go, you should have no trouble finding BC550C/560C at professional parts distributors like Mouser, Digikey, Farnell element 14, RS components and many other authorized independent distributors - world wide.
Don't rely on Chinese Ebay stores because you don't really know what generic part or fake is really inside the unbranded stuff you buy. For example, your 2SD667/B647 won't be genuine anyway - how would you know what they really were? Here's my current order for genuine Fairchild /On Semi parts as an illustration of what to buy - other brands use different suffixes to describe leads and packing variations:
Ian
Old 18th April 2017, 08:29 PM   #10
Hi Ian,
Thanks for your reply.
I live in Germany, I will order the parts from RS or reichelt.
NAIM NAC 42.5 Vintage for my updated NYTECH CPA 602 - 2012 NRWler04 Analog Line Level 15 21st October 2012 10:35 AM
Naim NAC 552 Preamp Melon Head Solid State 26 4th March 2009 12:34 PM
SELLING: NAIM NAP140 + NAC 42.5 + grey snaic clable aquila.77 Swap Meet 0 5th March 2006 05:00 PM
42 single ended ThSpeakerDude88 Tubes / Valves 38 19th November 2005 10:02 PM
Copyright 1999-2017 diyAudio
