I want to replace the 4 large capacitors in this amplifier but without pulling them out I am
unable to determine what type of terminal they have. I assume they would be 'snap in'
These capacitors mount directly on a pcb. Each one has two extra terminals for stabilizing.
The terminal spacing is unusual, so you may have difficulty finding replacements that are
mechanically compatible.
No issue with spares. The fitting is a common size.
This will give you the manufacturers part number for chasing in Ozz.
ALP22A103CD063 | KEMET Aluminium Electrolytic Capacitor 10000?F 63 V dc 35mm Can - Solder Pin, Radial ALP22 Series | KEMET
