After 14 years of loyal service, my Audiolab 8000a has just developed a fault. I get a constant 'thin' output from the left channel regardless of volume or balance control position. Defeating the tone controls also makes no difference. I've also connected the pre-amp output to another power amp and the fault is still there so it looks like the problem is with the pre-amp stage. Also I've connected the 'record' output from one of the tape recorders inputs to another amplifier and this works OK, so the fault lies between the record output stage and the pre-amp output stage. Can anyone help or does anyone have a circuit diagram / PCB layout drawing for one of these amps ?Many Thanks |
#2 |
My Audiolab 8000A has just developed a fault. I get a constant low output from the volume control position. I've control the volume with the remote control of the CD source. So, one day, some components of the circuit burned and no tecnical support are avaiabla because the constructor is out. The burned components are so black that's impossible see the values, for eventually replace it. Can anyone help or does anyone have a circuit diagram / PCB layout drawing for one of these amps ?
#3 |
Account Disabled
..has either of you even bothered to run a search on the forum before posting..?
![]() http://www.diyaudio.com/forums/showt...296#post651296 |
#4 |
on the burned components, can you read the values off the same part in the *other* channel, or is this in some common stage like the power supply (should be pretty generic)?
#5 |
About the burned components, I can't read the values off the same part in the other channel, I can't find the "twin" components. I think they are be pretty generic, and the location is near from the power supply. Exactly between the channels and the power supply. Some of they are a resistor or resistence.
#6 |
I have news about my problem. So, the burned componets seem to belong to a one of the channels, but it's not easy to find the same in the other channel because the disposition of the components is different. One of these looks like a diode in the diagram of Steven, but in the circuit it is a resistor. (?) Thanks, specially mikers & Dr. Photon. |
#7 |
I attached two images, but only one has appear. The other image is the situation of the burned components, respect the complete circuit. Thank you |
#8 |
I have the same problem, but after inspection I cannot find any burnt components. Are there any fuses on the board that could have burnt.
Please let me know. |
#9 |
Hello everybody,
I just bought a used Audiolab 8000A amp. After unpoacking it appeared that the right channel always gives a very low output, regardless of the volume. I also connected another amp to the pre-amp output with the same result. On the board no noticeble damage is present. What could have happened, does anyone know if the 8000A has any internal fuses that could have blown. I found the same problem in another thread, but no solution was given. Thank you very much. |
#10 |
I wonder if it is a broken volume control? Try connecting to tape out to hear/measure if the signals match. try connecting your input to a different input RCA, again comparing at the pre-amp outputs and tape outputs. As you can see, with a two channel multi-input/output you have a lot of options to find bits that work and try to home in on the bits that don't. |
| Audiolab 8000a | dantzig65 | Solid State | 9 | 6th June 2011 02:48 PM |
| Audiolab 8000A fault | davebungo | Solid State | 3 | 2nd October 2008 02:09 PM |
| Audiolab 8000a strange fault | wilfulmissing | Solid State | 3 | 11th August 2007 04:05 AM |
| audiolab 8000a | davephot | Solid State | 35 | 26th November 2006 10:25 PM |
| Audiolab 8000A fault in power amp side - HELP! | carribey | Solid State | 17 | 25th April 2006 06:23 PM |
