Technics SA-GX303 relay clicking - diyAudio
Old 20th March 2017, 11:06 PM   #1
ACS is offline ACS
Default Technics SA-GX303 relay clicking
Just picked up a Technics SA-GX303. Here's whats happening...everytime I turn it on, everything is fine for the first 10 minutes...then the relay clicks 3 times...then it never happens again..untill I shut it off and turn it back on. So basically, power on...10 mins later *click*...few more minutes after that *click*...few more mins *click*...and thats it...after that it plays all day long. What am I dealing with here??
Old 21st March 2017, 11:39 AM   #2
Konzentr8's Avatar
Before investigating deeper first of all check all the speaker connections for any stray strands at the amp outputs and speakers themselves there could be a slight short thats triggering protection intermittently without shutting down , does the sonnd dropout when it clicks?
If it's not broken let's fix it until it is
Old 21st March 2017, 04:27 PM   #3
ACS is offline ACS
Theres no speakers hooked up to it, it is only being used ad a preamp to drive a crown xls drivecore 2 series. When the relay clicks the sound drops out or pops yes
Old 21st March 2017, 06:06 PM   #4
Konzentr8's Avatar
How have you hooked it up to the Crown ?
Old 21st March 2017, 06:16 PM   #5
ACS is offline ACS
I soldered rca's to the input signal pins on the amp IC to make a preout. Pins 13 & 15 on the 3206 IC. Thats irrelevant to the relay issue, as it was doing it before i made the modification
Old 21st March 2017, 06:16 PM   #6
ACS, this kind of intermittent problem can be hard to track down and I don't need to repeat all the reasons that d.c. coupled amps can fail. I have one that does this for the last few years and I can't seem to find the problem. First, hook up your meter to the speaker terminals (better yet the input to the relay) and monitor the d.c. offset. Confirm that wandering d.c. offset is in fact putting the amp into protection. Also note which direction the d.c. offset seems to go.
Sometimes the amp can be OK, but the protection circuit itself can develop problems with failing capacitors, transistors, etc. After your experiments, why not post your findings? Another pain is always oxidized bias potentiometer that becomes intermittent. Here is your summer project.
RA
Need Relay for Technics SA-5270 BobMichaels Solid State 0 10th February 2015 06:30 PM
Technics SA-410 Relay dturn1111 Solid State 0 14th January 2014 04:08 AM
Sony V333ES Amp with a rapid clicking relay and no power fbcds82 Solid State 5 19th July 2011 06:56 PM
Adcom GFA-1 Clicking relay repus1 Solid State 0 7th May 2010 11:12 PM
Pioneer SX-838 -- random no sound output, clicking relay VTbimmer Solid State 11 26th February 2004 12:12 AM
Copyright 1999-2017 diyAudio
