Just another "recapping headache" thread
Old 20th March 2017, 06:54 PM   #1
soma89 is offline soma89  Canada
Default Just another "recapping headache" thread
Ok so i got a nice little working NIKKO TRM 210 AMP for my first recap job. The circuit is simple, as its a lil 12wpc unit.
Replaced all the caps. Thought everything was goin well. Powered it up and one cap was smoking!(2200mf 63v..C669 on schematic). Noticed that it was inserted the wrong way around (im an idiot, i know).
Anyways so i just got a new cap from digikey but now i get no sound at all!
Judging from the schematic, there are no reference voltages or fuses.
How would you recommend i start troubleshooting?
I have a multimeter, signal tracer, oscilloscope, signal gen.
Thanks!!
Old 20th March 2017, 07:01 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
At first, try to measure any fuse in the device. The reversed cap may overload the rectifier, and perhaps tripped any protection system, including a thermal cutoff INSIDE the traffo itself.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 20th March 2017, 08:22 PM   #3
tvi is offline tvi  Australia
tvi's Avatar
Does the power light come on?
The only fuse I can see is mains fuse on the rear panel
I assume you changed the cap i circled in the schematic... check the voltage at the arrow it should be about 1/2 of V+
Do you have a V+?? check at the centre junction of D691
hope this helps
regards
james
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 20th March 2017, 08:23 PM   #4
mbz is offline mbz  Australia
I'm guessing C670, please correct me. You may have smoked the output TR's.
If C670 then check all power amp TR's in relevent channen(Q652,4, 654,6,8, 660,2).
I would expect this to take out one side only. Please share with us the cap number
Cxxx.
Old 20th March 2017, 08:28 PM   #5
tvi's Avatar
Yeah if its both channels that are dead and its not the fuse next might be the bridge rectifier?
Ambrose Bierce
Old 20th March 2017, 09:32 PM   #6
hope this helps
regards
james
Yes, C 669 is culprit! Im getting 0v there. However i am not sure how to determine V+.
Can anything be determined by the mains fuse?
Old 20th March 2017, 09:40 PM   #7
Powers up! No sound though
Old 20th March 2017, 10:23 PM   #8
Cxxx.
It is c 669 on schematic.
Old 20th March 2017, 10:44 PM   #9
I dont see a fuse. Only these circuit breaker things with push buttons (not familiar with them at all)
Old 20th March 2017, 11:25 PM   #10
tvi's Avatar
See if you have continuity across the circuit breaker with the unit UNPLUGGED
Have marked the V+ on attached pcb pic
Ambrose Bierce
Just another "recapping headache" threadHide this!Advertise here!
SymAsym - "The Sequel", AAK's Rev_1.4 PCB Builders Thread AAK Solid State 161 19th December 2016 09:23 PM
Ben's "Hi-Marks" Fullranger + Isodynamic Tweeter 2-Way Build Thread Ben_Tech Multi-Way 177 27th January 2016 03:41 AM
I'm gonna need some elektric help "Pioneer PD-S505" (First Post/Thread) UsernameTaken Digital Source 4 13th September 2015 07:24 PM
SB acoustics SB12MNRX25-4 "full range" Build thread wintermute Full Range 95 4th March 2014 09:15 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
Copyright ©1999-2017 diyAudio
