Old 17th March 2004, 04:30 PM   #1
jam is offline jam  United States
jam's Avatar
Default Amplifier Topologies
Do you have any particular topology or design you like. Please post it here and any reasons why you care for the design. Maybe our resident guru's (Pass, Curl and Hansen) would join in and share their ideas.
My entry............
Old 17th March 2004, 05:51 PM   #2
subwo1 is offline subwo1  United States
subwo1's Avatar
Do simulated only circuits count? Or are you interested in only built and proven amps?
USMPS
http://groups.yahoo.com/group/switchmode/
Old 17th March 2004, 06:49 PM   #3
jam's Avatar
Simulated circuits do count but there is nothing like a working unit because simulations don't always tell the whole story, but any ideas are welcome.
Jam
Old 17th March 2004, 07:09 PM   #4
The one and only
Nelson Pass's Avatar
You don't have to build or simulate them to make them
interesting, but I suggest that you keep them relatively
simple, so that the point of the topology is visible to
most.
Old 17th March 2004, 07:24 PM   #5
jam's Avatar
Good point Mr.Pass,so here goes..................comments.
Old 17th March 2004, 07:51 PM   #6
The one and only
Your input ground is attached to the negative rail.
Old 17th March 2004, 08:01 PM   #7
subwo1's Avatar
I removed the diode and got better performance. With it in, the clipping was premature on the positive peaks, while without it the situation was better. Could you explain what the diode does?
Overall, not bad I think for just one gain stage.
USMPS
Old 17th March 2004, 08:06 PM   #8
mwh-eng is offline mwh-eng  United States
Is there a connection at the bottom 470 ohms and the cathod of CR470?
Old 17th March 2004, 08:09 PM   #9
jam's Avatar
In the original the input is transformer coupled.
http://perso.wanadoo.fr/jm.plantefeve/Gibouin.html
hope you can read French. Has anyone built this?
Jam
mwh-eng the answer is no.
Old 17th March 2004, 08:15 PM   #10
jam's Avatar
CR470 is a current diode.
http://www.datasheetcatalog.com/datasheet/C/CR470.shtml
Power Amplifier Output Topologies danville Solid State 58 7th March 2010 05:40 PM
different psu filter topologies ? metebalci Tubes / Valves 4 4th August 2004 07:53 AM
Page generated in 0.16554 seconds (46.40% PHP - 53.60% MySQL) with 11 queries
