Old 17th March 2004, 02:11 PM   #1
kmj is offline kmj  Sweden
kmj's Avatar
Default Easy DIY RIAA-preamp wanted.
Hi, I am in need of a preamp for my old turnable.
It seems that the guys at HK neglected to put a phonoamp in my reciever......
so instead of buying one i thought that i perhaps could start up a new hobby and build one myself. But since there are so many schematics out there i thought that you guys could recommend one thats quite easy to build and with complete schematics for powersupply and amp-stage....
anyone got any suggestions?
imput sencitivity and impedance of the existing amp is 200mV and 47kOhm
Old 17th March 2004, 03:18 PM   #2
Keld is offline Keld  Sweden
Keld's Avatar
Default Re: Easy DIY RIAA-preamp wanted.
http://www.hagtech.com/bugle.html
"What is done by what is called myself is, I feel, done by something greater than myself in me."
James Clerk Maxwell. 1879
Old 17th March 2004, 03:28 PM   #3
jackinnj's Avatar
national has an RIAA phono amp based upon the LM833 chip on their website -- look it up on the LM833 product descriptor.
i was quite pleased with the results (but you could use a quieter chip if you so desire.) i looked for the PCB layout on my drive, but must have erased it.
Old 17th March 2004, 03:37 PM   #4
kmj's Avatar
thanks, but there was only the partial schematic.....
im not looking to buy a kit, only the parts and solder them together and put it all in a chassi (to make short summation )
much cheaper that way, and a kit feels like cheating......
Old 17th March 2004, 03:38 PM   #5
kmj's Avatar
national???
Old 17th March 2004, 03:55 PM   #6
coffin is offline coffin  Taiwan
coffin's Avatar
http://www.national.com/pf/LM/LM833.html#Datasheet
and this:
Check Out MY El Cheapo Phono Preamp!
Old 17th March 2004, 04:17 PM   #7
kmj's Avatar
thank you, coffin.
The el cheapo seems to be what im looking for.
could a PCB transformer be used instead of a torrodial?
how would a powersupply look in that case?
Old 17th March 2004, 07:06 PM   #8
jackinnj's Avatar
thank you, coffin.
I use a small PCB transformer -- be careful to keep the a.c. line inputs away from the phono inputs. for the power supply I use a pair of LM317's and a pair of LM337's -- for the + and - rails.
the first regulator is set to 19 volts, the second to 15 volts -- the two regulators in series seem to prevent "turn-on" thump.
Old 17th March 2004, 07:37 PM   #9
kmj's Avatar
A friend of mine used this as a 15V supply....
with these:
U1,2: http://www.elfa.se/elfa/produkter/se/2021125.htm
trafo sec 2x15V: http://www.elfa.se/elfa/produkter/se/2014310.htm
could i use that and make it 2x12V instead using this:
http://www.elfa.se/elfa/produkter/se/7026.htm
just push the little brittish flag to change language on ELFA
Old 17th March 2004, 10:13 PM   #10
Keld's Avatar
The hole schematic is in the "User manual"
Wanted RIAA stage with 6SN7 sam8888ysl Tubes / Valves 20 30th July 2011 11:03 AM
~AC~ easy line/RF filter + surge supressor schematic wanted bluesmoke Everything Else 2 9th May 2011 06:06 AM
wanted RIAA schematic sam8888ysl Tubes / Valves 23 27th July 2006 01:00 AM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 01:52 AM
Page generated in 0.12516 seconds (70.58% PHP - 29.42% MySQL) with 11 queries
