Seperate analogue stage after DAC chip
Old 8th April 2002, 12:33 PM   #1
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Seperate analogue stage after DAC chip
Please see/find my enclosed file for the schematic.
I want to build my own analog stage for my minidisc player (which I use as a DAC.)
The DAC has 2 outputs per channel, therefore I want to have a differential buffer and then a gain stage.
I am no EE and barely know how these opamps work so I copy designs and put them together
Will my design work? Any thoughts on the design are appreciated (Except op-amp fetishes) It uses the TLE2027AI opamp. The only thing I don't want to change with this design
is the opamp. Cause I have a couple of them lying around :-)
Bas Horneman.
Old 8th April 2002, 05:27 PM   #2
Jocko Homo is offline Jocko Homo  United States
Banned
For starters......
The inverting input is a virtual ground. The non-inverting is 10K. You would need to put 10K in series with the inverting input to make it the same.
I assume your DAC is a voltage-out type since it has 2 outputs.
Jocko
Old 8th April 2002, 05:55 PM   #3
If I understand correctly I should add a 10k resistor to the - input of the first opamp?
I suppose it is a voltage output from what I've read (Sony MDS-JE510.)
By the way should I tap the outputs from IC 301 or IC 307?
Bas
Old 8th April 2002, 10:41 PM   #4
sonnya is offline sonnya  Denmark
sonnya's Avatar
Try looking at this. Much easy can you not do a balanced to singleended conversion.
Sonny
Old 9th April 2002, 12:37 AM   #5
Default Thank Sonnya...might try it after this project.
So I can compare the two with each other...
Bas
Seperate analogue stage after DAC chipHide this!Advertise here!
Analogue output stage maxpou Digital Line Level 0 18th April 2009 03:48 PM
Help on improved analogue stage p.heimpold Digital Source 1 17th March 2007 10:16 AM
TDA1540 analogue stage dariusku Digital Source 2 9th September 2005 08:01 AM
New analogue sub controller chip pinkmouse Parts 0 13th January 2005 05:49 PM
cdp analogue stage tweak ohynot Digital Source 2 11th July 2004 09:36 AM
Copyright ©1999-2017 diyAudio
