Old 19th March 2004, 09:39 AM   #11
deji is offline deji  Nigeria
Send a message via Yahoo to deji
allright i am getting a bit confused are u saying that the jack on my computer sound card where i connect my earphones is at line level
Old 19th March 2004, 09:47 AM   #12
Frank Berry's Avatar
Yes.
Frank
Old 19th March 2004, 10:14 AM   #13
and line level is the same thing as preamplifier level,which means i can hook up my earphones to the signal that drives a preamplifier right
Old 19th March 2004, 04:15 PM   #14
Diode is offline Diode  United States
That would be correct my dear fellow.
Just make sure that the volume is down as different headphones have very different sensetivities and very fine headphones will not take a lot of drive signal to be loud and clean.
In other words, turn the volume down so you don't take a chance on blowing the headphones.
Chris
The best audio is clean audio!
Old 15th April 2004, 03:29 PM   #15
hi group
i tried hooking up the sound card directly as u suggested but it didn;t work out well as in the sound was scratchy so i reverse engineered a goodmans 4210b deck to see what really happens to the auxillary signal applied to the jack at the back.so i constructed the circuit and it worked quite well,but thanks for your enlightenments
Old 15th April 2004, 04:13 PM   #16
sam9 is offline sam9  United States
sam9's Avatar
"i want to couple the audio output of my computer sound card to my stereo deck but "
No problem. I just take a <3.5mm phono>-to-RCA adapter and plug in the "line out" from my Audigy card into the "aux" input of my tuner-preamp.
Then I found a local radio station that also feeds it's broadcast into the internet. First I tun in that station on the tuner-pre, then connect to it via WinAmp. I adjust the WinAmp volume until both are at the same level. (Switching bacj and forth between "Aux" and "Tuner".) I next do the same thibg with a CD player that feeds the tuner-pre directly and withe the CD-R drivre in my PC. After that I no longer use the PC to control the volume - just the tuner-pre. Since the tuner-pre provides the same gain to allources, this ensures that the signal from the Audigy is the same as from any other line source.
BTW, the preamp drives a Slone 11.4 which runs a pair of old but excellent KEFs. Makes any powered "multimedia" system sound like the boombox it is!
Splitting A Line Level Signal. Noumenon Analog Line Level 0 10th August 2007 12:57 PM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
Line level signal delay circuit wigginjs Solid State 3 26th September 2004 02:51 PM
Line level signal delay circuit wigginjs Parts 2 24th September 2004 11:36 AM
Page generated in 0.08667 seconds (71.28% PHP - 28.72% MySQL) with 10 queries
