Luxman 5M21
Luxman 5M21
Old 18th September 2017, 01:29 PM   #101
rfitts46 is offline rfitts46  United States
carlmart,
quote [have you checked the junction between the FET and the cascode transistors]
no I have not. are we talking about this junction
Old 18th September 2017, 02:04 PM   #102
carlmart is offline carlmart  Brazil
Yes, that's it. At least you should know if the oscillation comes from the FET.
The oscillation I got on my simulation was cured in the driver's stage. Perhaps you might try it.
Old 18th September 2017, 02:37 PM   #103
QUOTE [Yes, that's it. At least you should know if the oscillation comes from the FET. ]
carlmart, Wouldn't oscillation be seen there because of the oscillation being supplied back to the input card via feedback.
Couldn't the oscillation still be occurring downstream from the FET and the oscillation being supplied to the input of the FET from the feedback?
As mentioned the DML modules have been swapped and the oscillation did not follow the DML module.
Old 18th September 2017, 04:12 PM   #104
OK. This is the complete original 5M21 schematic, included parts inside the DML.
The other schematic shows, in red, what cured the first stage oscillation.
You may try it and see if it works for you.
Start with isolating the driver resistors from the NFB and add the 10uF cap. That should be easy to implement, with just one retrofittable track mod.
For lowering the resistors to 4.7, you can just add 10R resistors on the copper side.
File Type: jpg Luxman 5M21. faxtory schematic_one channel.jpg (700.5 KB, 18 views)
File Type: jpg Luxman 5M21. faxtory schematic_osc mods.jpg (830.2 KB, 18 views)
Old 18th September 2017, 05:10 PM   #105
Forgot to say that it cured the oscillation on the LTSpice simulation, of course.
Luxman 5M21Hide this!Advertise here!
luxman help orsen Solid State 2 2nd July 2014 11:32 AM
Luxman C-1000 Carlosraj Solid State 5 2nd March 2012 07:38 AM
Luxman joelfl Solid State 3 18th August 2010 10:05 AM
Luxman D-404 Rob M Digital Source 0 21st November 2004 07:44 PM
5M21 Service Manual Needed NickC Solid State 0 31st July 2003 10:16 AM
Copyright ©1999-2017 diyAudio
