nad 3020b cap replacement problem - diyAudio
Old 21st January 2017, 04:52 PM   #1
blrh93 is offline blrh93  United Kingdom
Default nad 3020b cap replacement problem
hi, i have a nad 3020b amp it recently developed a buzzing
i had a look inside and a few of the caps where bulging on the top
so i decided to replace 6 caps in total
here is what i replaced the originals with
and main psu caps
so after getting it back together, it has fixed the constant buzzin, but over around 1/3 volume the amp develops a noise that sounds like a record scratching, this starts with the bass
have i used the wrong tye of capacitors? i made sure to replace with the same voltage and capacitance ratings
any help appreciated
regards Ben
Old 21st January 2017, 05:29 PM   #2
rayma is offline rayma  United States
Do you have a meter for checking voltage?
Old 21st January 2017, 07:01 PM   #3
i have a multi meter, what should i check?
Old 21st January 2017, 08:01 PM   #4
Ok, set it to DCV. If not autoranging, set it to an over 40V range.
Connect the black lead to chassis ground and use the red lead to check voltages of -
1] red speaker outputs of both channels, for 0VDC.
2] main power supply voltages, both positive and negative, for 28VDC on either.
3] regulated voltages, both positive and negative, for 25.8VDC on either.
Old 22nd January 2017, 09:15 AM   #5
Hi!
I experienced similar issue, some caps should not have too low esr in 3020 model, especially those small ones, try solder back old caps, and try the sound after recaping again every single cap.
regards, Pawel
Old 22nd January 2017, 10:22 AM   #6
diyAudio Moderator Emeritus
jean-paul's Avatar
Best tip: buy industrial quality caps from a real distributor so you can be assured you buy the real thing. I would not use Sancon if I was given them for free.
It's only audio. Member of the non modular PCB design committee
Old 22nd January 2017, 01:50 PM   #7
Welcome is offline Welcome  France
Welcome's Avatar
Indeed, it looks like you've used essentially fake caps. Those things might not work as intended. I recommend using the originals instead of those things.
Old 22nd January 2017, 06:56 PM   #8
what brands should i look for? are the nichicon ones ok?
Old 22nd January 2017, 06:57 PM   #9
jean-paul's Avatar
If you buy them from a distributor then: Yes.
Old 22nd January 2017, 08:25 PM   #10
I had the problems using original Nichicon FGs as C615, 616, 625, 626 https://www.elektrotanya.com/nad_302.../download.html because the amp started to act like motorbike engine, and had back to factory mounted, then the amp began behavior like it should.
My guess was that they had too low esr...
All other caps you might to exchange with any you like but those four are enginestarter
regards, Pawel
Any Owners of NAD 3020B rwaters2 Solid State 6 23rd March 2015 07:18 PM
Need NAD 3020b service manual Tuneslover Solid State 4 21st April 2013 02:24 AM
NAD 3020B Servce Manual StevieRay Solid State 0 20th February 2012 03:23 PM
nad 3020b idle current reddish75 Solid State 4 4th July 2008 02:46 PM
Problem with treble on NAD 3020B Gareth B Solid State 1 15th January 2007 12:06 AM
Copyright ©1999-2017 diyAudio
