Old 14th March 2004, 10:46 AM   #1
akira is offline akira  France
Default [OT] Design a MOSFET heat Load
Hi all,
Sorry for the slight off-topic post but I needed help from MOSFET masters.
I m building a Phase-change cooling for my computer. To test the cooling power I d like to try it on a heat load. (Not directly on the CPU). Therefore I d need a heat load that would be ajustable between 60 and 200W. I thought MOSFET would be a good try.
Could any of you, masters of the MOSFETS, draw me a quick shematic describing how I could do that ?
Thanks a lot,
Akira
Old 14th March 2004, 10:19 PM   #2
subwo1 is offline subwo1  United States
subwo1's Avatar
The IRFP460N is rated for 280 watts. Mount both mosfets on the heatsink you are testing as the cooler. The value of R1 will need to be altered slightly because its value determines the maximum voltage which can be applied to the gate of the load mosfet. If you make it 4.3k or 3.9k, for example, you could then lower its value down to what you need by placing a high value resistor in parallel with it.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 17th March 2004, 06:36 AM   #3
Coooool. Great, thanks very much. I ll try that.
problem with heat of MOSFET yanuarbob5150 Class D 8 9th February 2009 03:11 PM
Mounting Mosfet on Heat Sink ttan98 Pass Labs 11 14th April 2006 09:31 PM
transformer load on MOSFET??? AudioGeek Solid State 2 17th July 2004 12:32 AM
Heat Sink for Dummy Load mclagett Parts 7 27th May 2004 02:04 AM
[OT] Design a MOSFET heat load akira Pass Labs 3 14th March 2004 09:08 PM
Page generated in 0.27468 seconds (20.00% PHP - 80.00% MySQL) with 11 queries
