#31 | |
Move the output Zobel, and replace the poly caps with high-quality non-inductive types. The Zobel worked really well with a .1µf and a 5.1 ohm 3W resistor. You can also replace the input opamp with whatever you like, but when I did the above amp 4+ years ago, I had a bunch of opamps here, and I thought the 5532 sounded best for this amp. Edit: ...and yes, in that drawing in post #2 has an error...that cap in the Zobel filter is 0.1µf, not 1µf. |
#32 |
Oh, and here is where I got the complete service manual for the 7070 from:
http://www.eserviceinfo.com/download...nsui_7070.html |
#33 | ||
regards Andrew T. |
#34 |
I think that putting a wirewound resistor in series with a cap to form a zobel damping network is wrong. The wirewound has inductance and creates a resonant circuit in a place you really don't want it.
Carbon composition resistors are the right part to use there. Unfortunately, I don't think they are made anymore, although you can sometimes find them through surplus and nos dealers. Also it is debatable as to whether the output terminal of the amp should be the feedback point or not...depends on the circuit, really... although in this case it helped fix your problem. |
#35 | |
It's pretty simple really. At HF the inductor goes open circuit and the capacitor goes short circuit............... |
#36 | |
#37 |
Thanks EchoWars!!!
I took out the driver boards from this amp, they need good cleaning, capacitor replacement and Zobel filter mod. This amp is pretty heavy and philips used cheap and thin metal chasis. Only the heatsinks holding this amp together. If heatsinks are removed the front, back and bottom parts are not connected, they were held together by the heat sinks. I wish they used littlebit strong metal bars to held the chasis. If anyone wants to remove the heatsinks to remove driver boards just remove one heatsink at a time and put back this hint sink before removing the other. Otherwise it is pretty nasty to put together because of this nasty heavy power transformer. Thanks, routhun
routhun |
#38 |
once i had to fix a double deck cassete player from philips ....
of course you need torx and some other special tools to remove things from it then of course you need three working hands to do that since two are not enough and of course there is point when clik sound appears and your shop is full of coils springs and plastics ..... philips R&D ha ha ha
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| is there a circuit for a power supply to power the differant add on clocks | frank2395 | Digital Source | 1 | 30th June 2005 09:33 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| JBL model 6290 power amp (oscillating) | wuffwaff | Solid State | 1 | 12th March 2002 01:41 AM |
| Page generated in 0.14075 seconds (75.85% PHP - 24.15% MySQL) with 11 queries |
