amplifier smps
amplifier smps
Old 6th April 2002, 11:26 AM   #1
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Question amplifier smps
Nowadays in high power car audio, DC-DC inverter smps is the NORM.
Has anybody tried seperated cabinets for power supply and smps stages, and rigorous filtering, more so for high power PA applications.
I have heard a big touring rig running Carver smps power amps.
(michael Jackson tour - not a valid sonic yardstick ! )
The general opinion of these is that they are a bit bass light, elsewise they seem ok.
I am also looking for advice regarding smps topology and critical components.
Thanks, Eric.
Old 6th April 2002, 11:55 AM   #2
tvi is offline tvi  Australia
tvi's Avatar
Some seem to think they are great.
<a href="http://www.audio-consulting.ch/pipeSMPS.htm"><img src="http://www.audio-consulting.ch/pipeSM1.jpg"></a>
<i>A C37 wooden version using no PCB
Very high efficiency HF Supply featuring 100% Silver Power Transformers.
They power our reference SE 300B amplifier based allowing absolutely new levels of performance</i><hr width="95%" align=center>
<a href="http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1='5612646'.WKU.&OS=PN/5612646&RS=PN/5612646">US Patent 5,612,646</a>
<i>"A linear audio amplifier includes a push-pull pair of vacuum tubes operating in a linear amplification mode coupled through a pair of dc-dc switching power converters to an external load impedance"</i>
James
Old 6th April 2002, 03:48 PM   #3
mrfeedback's Avatar
Default tripping on C37 ?
Hi James, thanks but this was not quite what I had in mind - not even the remotest bit really.
These guys seem pretty intoxicated on C37 - maybe the fumes are a little too strong.
Next suggestion please.
Eric.
Old 6th July 2007, 05:50 PM   #4
CHACALPOWERS is offline CHACALPOWERS  Bahrain
CHACALPOWERS's Avatar
Default About smps amplifiers
Look this!!
Bye!!
Old 7th July 2007, 04:17 AM   #5
anatech is offline anatech  Canada
anatech's Avatar
amplifier smps
Hi Eric,
The Carvers sound like they were PM 2.0's. They are not normally light on bass. If the AC supply is weak they may cave on loud bass notes. Could have been the speakers and venue as well. EQ's ?
A switching power supply can work very well for audio amps. Easier to filter the noise out. The real gottcha will be going from a 12 VDC system up to the bipolar 50 VDC and up that big power needs. Some early Linear Power amps had supplies way up there. One I think was +/- 60 VDC!! Here, the car's system had trouble keeping up to the demand.
Going from a 120 VAC supply to whatever is needed is much better, and it gives you the opportunity to pre-regulate your supply voltage(s). Well worth pursuing this angle.
Eva is one member that knows a great deal on this subject. If she has time, I believe she could really help you along. You do need to spec out your supply and expected rails and power required from the supply (not the output power of the amp).
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 7th July 2007, 11:40 AM   #6
Default my smps
Hi
Looh my simple design (IGBT).
Old 7th July 2007, 11:49 AM   #7
Default SMPS car audio AMPLIFIER
This is my SMPS car audio amp. Input 13.8V/ output +65V/-65V. 12 FQP50N06 mosfets, 2 inches toroidal transf., SG3524 PWM, optozener regulated .
REgards
amplifier smpsHide this!Advertise here!
Dragster Amplifier bad SMPS ben12345 Car Audio 38 4th February 2010 03:22 PM
DIY smps + LM3886 Car Amplifier rwaudio Car Audio 0 30th October 2008 03:06 PM
car amplifier SMPS KettermanJ Car Audio 6 16th October 2007 12:31 AM
SMPS for 2+1 amplifier? Dxvideo Chip Amps 1 5th October 2005 01:01 PM
I want to build car smps and car amplifier himanshuraval Car Audio 0 20th February 2004 12:40 PM
