I have worked with tubes and transistors all my life, but never really understood the common everyday transistor power output circuit. I need a source of design and repair theory for the single power supply circuit where the speaker takeoff point is set to half the supply voltage using feedback to the input. Just don't have a good working knowledge of the circuits. Can anyone recommend a good url or publication I could use to enlighten myself? Thanks, Ken
#2 |
The one and only
Well, if you want to start with the dumbest example, try a
Zen amp at www.passdiy.com |
#3 |
What is it that you need to understand? Some questions can be answered right here. If you want to design your own amplifiers, you need more depth of understanding than if you're just trying to fix a broken one.
My favorite book for generic transistor amplifier theory is the RCA Solid State Power Circuits Designer's Handbook, long out of print. If you search Amazon dot com you'll find hundreds of "how to" books for repairing electronics stuff.
dave |
#4 |
Maybe a start could be to post a schematic of some amplifier
you want to understand but don't, and try to ask somewhat more detailed questions referring to that particular schematic. That might provide a good starting point for people to try helping you. There are so many different topologies that seem to fit your description, so the question is somewhat to vague and general. |
#5 |
Here, lets talk about this one, 400watts a side RMS into 4 ohms, a very common comercial power amp.
have a peak !
Greg, aka A31Ford Manitoba, Canada |
#6 | |
Banned
Try this 1967 article by Bart Locanthi, the original designer of the most commonly used bipolar power amp output stage, originally called the "T circuit": http://users.ece.gatech.edu/~mleach/.../tcir/tcir.pdf Also see this page for schematics and detailed circuit description of a DIY amplifier that people have been building since the mid '70s. http://users.ece.gatech.edu/~mleach/lowtim/ |
#7 |
The one and only
Jeez, why don't you hand this guy a vurrent Levenson circuit
and give him a heart attack? |
#8 |
You may find these a good read:
http://www.iirg.org/ticom/neets/ especially module 7 & 8 for SS & basic amplifier circuits. |
#9 |
about feedforward ,please!
thanks a lot! |
#10 | |
Banned
| Education | Element138 | Tubes / Valves | 18 | 5th March 2009 06:45 AM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| TV Horzontal Output Transistor for output stage..? | ronybc | Solid State | 46 | 10th October 2005 02:26 AM |
| electronics education | magicfunk | Everything Else | 1 | 29th September 2004 09:12 PM |
| Site w/ several circuits- Tube & Transistor | vdi_nenna | Everything Else | 1 | 10th April 2001 03:16 AM |
| Page generated in 1.75471 seconds (7.16% PHP - 92.84% MySQL) with 10 queries |
